Old 05-16-2010, 05:51 AM
groovebrother groovebrother is offline
Default where is the command+space gone ?
hello evryone
since i updated to 10.6.3 this shortcut doesn't work anymore.
I whent back in 10.6.2 (format + clean install) and i cannot get it back
i tried this but didn't do any good
any clue ?
PT8.03cs2
thx
Old 05-16-2010, 06:06 AM
Hanswurstlsepp Hanswurstlsepp is offline
Default Re: where is the command+space gone ?
Works here.
When I press cmd/space it punches in and out IF quickpunch is enabled.
Maybe it got s.th. to do with the window-focus (yellow A-Z icon) ? Is it enabled in the edit-window ?
...just a thought...
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 05-16-2010, 06:18 AM
Just checked here - it got nothing to do with window focus.
But it'll definetely only work if u use one of the punch modes (right click on record button).
Cheers, STeff
Old 05-16-2010, 11:50 AM
it is enabled as it is for the "A-Z" icon in the edit window.
Old 05-16-2010, 11:51 AM
thx to you,
And it used to work with me what ever i am in punch mode or normal mode
Old 05-26-2010, 09:55 AM
nothing i can do so, i finally turned back to 10.5.8 with PT8.0.3cs2
evrything is okay now
Old 05-26-2010, 11:50 PM
bashville bashville is offline
I've never ever had that not work, EXCEPT if I've reached my voice limit where it doesn't have the extra voices needed to do quickpunch. But then it gives me a warning. I never use mouse clicks for transport.
On the latest update with Snow Leopard.....
Old 05-26-2010, 11:55 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Did you disable "Spotlight" in your mac preferences?
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 05-27-2010, 02:59 AM
yes i did ... as well as all digi's recomandations to optimize the mac for pro tools
Old 05-27-2010, 06:34 AM
tj_davies tj_davies is offline
Originally Posted by groovebrother View Post
hello evryone
any clue ?
PT8.03cs2
thx
I have changed to using the F12 key to record years ago. Much easier, faster and less problems (such as missing the Command key by accident and not recording but playing back and then missing the best take ever!).
I remember though, that there used to be a problem in the Import Audio window, that the order which key you released first made a difference whether Pro Tools would preview the audio file or not. I think you had to make sure you released the space bar before the command button to preview the audio - maybe it's the same problem with your recording action.
All the best,
Timothy
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Command-space bar not working zoff Pro Tools M-Powered (Mac) 19 09-05-2020 07:43 AM
f12 words, but command space doesn't? hornedrum macOS 7 01-11-2015 09:28 PM
Command + Space shortcut in Snow Leopard oha 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-17-2009 08:49 AM
TL Space TDM Plugin causes Command 8 to lose communication jacobfarron ProControl, Control|24, Command|8 3 06-20-2008 09:54 AM
can't record with command-space cebolao Pro Tools TDM Systems (Mac) 4 11-14-2001 01:23 AM
