Old 03-09-2010, 12:45 AM
Studio Studio Studio Studio is offline
Default Copy special>plug-in automation is greyed out
I noticed my "copy plugin automation" is greyed out and i'm not able to copy the automation. How do i turn it back on?
Old 03-09-2010, 06:49 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Copy special>plug-in automation is greyed out
Open automation window and select plugin? apple+4 to open window click on plugin it turns red
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-09-2010, 08:08 AM
That's what i thought, but it's turned on (red).
Old 04-07-2010, 07:15 AM
tilman tilman is offline
From the manual:
Page 934:
Plug-in Automation Copies only the plug-in auto-
mation that is shown. Then it works but is not usable for me.
But I found the way to do what I want
CMD + Shift + C
for copying Plugin Data.
cheers
Old 04-07-2010, 07:57 AM
Mt.Everest Mt.Everest is offline
Originally Posted by tilman View Post
From the manual:
Page 934:
CMD + Shift + C
cheers
Are you looking specifically to ONLY copy plugin automation or ALL the automation (volume, mutes, plugs, etc) during a specified section? Cuz Ctrl-CMD-C and Ctrl-CMD-V will do that for ya. I often do that after I do all my delay throws and volume rides etc for Chorus 1 and then copy and paste all that automation data to each subsequent chorus with that one keystroke.
MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O
PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8
PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626
•••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!•
Old 04-07-2010, 08:27 AM
I searched a way to copy an EQ7 Setting from one audioclip to a different audio clip on an other channel - which has also EQ7 as insert.
I now do it with the following combination:
1. shift+cmd+c - to copy the EQ(a) setting
2. go to other clip on different channel
select whole clip open EQ(b) window: shift+cmd+v
to copy setting of EQ(a)
3. then alt+cmd+v to write to all enabled.
I am shure most of you allready knew this.....
Glad I can do this now!
cheers
Old 05-12-2010, 01:36 PM
Porky Porky is offline
^this...and I already have it enabled.
...and anyone know of a quick way to copy and paste plug-in automation from one clip to another without having to...open the plug in, latch, paste, write. It would seem that "copy plug-in automation" and "paste special-plug in automation" should do it, but I can't seem to get it to work.
added...the only way I can get the "copy special" to not be grayed out is if I open lanes containing the automated parameters, but that is REALLY inconvenient for PI's with a lot of automated parameters.
Dave
CBS TV Distribution/On-Air
PT 2019.6.0
S3
Copy/Paste Special Plugin Autom: greyed out? SD2 macOS 2 10-19-2011 01:34 PM
Copy special Plug-in automation shortcut simonyeah Post - Surround - Video 1 07-12-2010 04:41 AM
copy special-greyed out Porky Pro Tools TDM Systems (Win) 2 05-13-2010 08:30 AM
Copy Special: All Automation Quirk / Weird Nathan W. Pro Tools TDM Systems (Mac) 3 02-07-2010 02:00 PM
Paste Special To Current Automation Type Greyed Out paulmellors 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-04-2008 02:22 PM
