Old 08-01-2004, 07:20 PM
cdadoveMusik cdadoveMusik is offline
Default hooking up of 4 active monitors
I have The DIGI OO2 table top with 8 sliders...The manual does not talk about how to hook up 4 monitors that are active...I can only see the single set of Monitor outs R & L that would be controlled by the Monitor Level knob.
One curiousity I had is if I can use a 1/4" audio plug splitter like I do with the headphones or would this diminish the signal to the monitors in any way?
Help please...Sincerely...Cornell d'Angelo
Old 08-02-2004, 09:14 PM
Default Re: hooking up of 4 active monitors
Assuming you mean 2 sets of stereo monitors, the best thing is to buy the Samson C-control ($99) as it will allow you to switch between up to 3 sets of active monitors. Presonus and Mackie make similar units but at a much higher price. I would not recommend using "Y" cords as it may affect the response. If you intend to operate both sets of monitors at the same time, you will need to read the manual with any of the mentioned units to see which allows that(I believe the Presonus does).
Old 08-03-2004, 05:25 AM
where02190 where02190 is offline
I second the C-Control, best $99 you can spend.
Hooking up my monitors :D ranallicj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-29-2009 07:02 AM
digi002/hooking up monitors djkiller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-08-2009 07:49 PM
Monitors: $1500-$1800 budget . Which Active Monitors? Suggestions and Help Please. betsy Pro Tools TDM Systems (Mac) 52 12-15-2003 10:11 PM
Active Monitors for under $500 trib4orce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 09-16-2002 12:32 AM
Which active monitors should I buy? mlemos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 36 02-08-2002 12:06 AM
