Old 04-30-2019, 03:11 PM
uduwudu uduwudu is offline
Default Corrupt Guitar Plugin
Ok, I know it's old software but it is / was good. Le8 on 64 bit Win 7. Usually fine.
The problem is the guitar plugin turns into a space invaders type effect.
I thought this was a hard drive issue on the old computer.
Now using a different (new) computer. Reloaded Pro tools. Same problem with imported old track. There is only this file on the whole computer beyond Pro tools and system files.
Ok. So I created a new track on the new computer - same "space invaders" problem happens. What?! is going on?...
I can't quite understand where the problem originates. I thought this may have been an old problem easily fixed on a new computer. But corruption is still there and now I'm as puzzled as a jig saw on how to fix the thing.
Anyone have any ideas? Much appreciated.
Old 04-30-2019, 03:57 PM
Default Re: Corrupt Guitar Plugin
OK slight update and could be useful for any other poor soul with this problem.
In Xpand I removed the guitar sound in box A, changed it to another . This worked. Put the old sound in box C. That works. Put it back to box A. And it's still working.
Hopefully this is over. It just needed a little shifting of sounds back and forth. It may be due to a old hard drive problem where none of this worked but the effect carried over into the file prior to being imported into a new session...
Old 04-30-2019, 04:07 PM
amagras amagras is offline
Did you try using a bigger buffer size?
amagrasmusic.com
Old 05-01-2019, 04:42 AM
What guitar plugin?
Try updating to the latest version of PT8
your Fav Guitar plugin.... xrekcor AAX Plug-ins 34 12-12-2018 06:06 AM
what guitar amp plugin is the best? davidlustrup Eleven Rack 12 12-22-2010 12:29 AM
Good Guitar Plugin? Phlacc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 04-15-2010 03:16 PM
ni "guitar rig" plugin? hank hill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-23-2004 12:36 AM
guitar amp plugin poboo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-05-2003 12:22 AM
