Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 11-10-2014, 11:11 AM
ThrustTony ThrustTony is offline
Default Inputting a Kemper Profiling amp into Pro Tools?
Which is the best way to input a Kemper into Pro Tools?
Is the best way to DI it straight into the front of the interface or can you use it as an interface via USB.
I tried using it as an interface via USB but Pro Tools wouldn't recognise it as hardware and wouldn't start up.
Old 11-10-2014, 11:45 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Inputting a Kemper Profiling amp into Pro Tools?
The Kemper does not support recording via the USB port.
You would either have to run the main outs into your audio interface analog ins or, if your audio interface supports it, use the S/PDIF connection.
Will
System Details
Old 11-10-2014, 12:30 PM
Raoul23 Raoul23 is offline
I use both the SPDIF and analog outs to connect my Kemper to 192 interface. Depends on what I'm planning on in the session :)
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 11-10-2014, 12:52 PM
Thanks for your held guys.
Is one method of connection clearer than the other.
I tried going from the monitor out but it didn't sound as clean on clean sounds as it does through the Kemper on it's own. It sounded like the sound was being coloured somewhere a long the line.
Do I take one lead from each main out and connect each lead to the interface, to input 1 and the other to input 2 on my avid Mbox 3G?
Old 11-10-2014, 01:34 PM
If you set the main out to master mono you can just use 1 lead from the main out to 1 input on your Mbox
Raoul Crane
Old 11-10-2014, 02:51 PM
Glenjb Glenjb is offline
Spdif if you have it because otherwise you will be converting to analog and back to digital for no reason. Spdif keeps it a digital signal.
Old 12-02-2014, 08:57 AM
I have my 2 Spdif leads now and have tried them from the back of the Kemper in out to the in outs on my mbox but nothings happening.
on the armed channel in pro tools 10 it says spdif mono l and spdif mono r which I've selected but nothing happens
Any ideas how I get this up and running?
Old 12-02-2014, 11:36 AM
junkgear's Avatar
See this post (Setting up SPDIF) on the Kemper site. They discuss how to setup S/PDIF properly.
Will
System Details
Old 12-02-2014, 01:01 PM
Thanks very much, I'll check that out now
This is crazy! Kemper Profiling Amp Benoni Eleven Rack 46 01-17-2013 06:29 AM
Kemper profiling amp?? Raoul23 Eleven Rack 18 01-08-2013 10:32 AM
Kemper Profiling Amp - Video Obsidian Dragon Eleven Rack 0 03-23-2012 06:17 AM
NEW PRO TOOLS USER - TROUBLE INPUTTING AUDIO JTM Digidesign Hardware & Software 0 08-23-2004 04:45 AM
midi inputting wrong notes in pro tools chagos MIDI 1 06-14-2004 06:44 PM
