  #31
Old 02-17-2014, 01:13 PM
toddg7777 toddg7777 is offline
Default Re: Eucon 3 - Artist Control not connecting to PT
Just want to report in with same problem as described here. Doesn't work with static IP or DHCP. Doesn't work with Eucon 3.01 or 3.1. Start MC before and after boot up. Start Artist Mix before and after boot. Can't get anywhere.
When I went into network settings and set static IP while trying that solution it worked one time but never again.
I read about the bad connection state and it sure seems like that is it but I cannot get any sequence of events that reliably connects my Artist Mix to PT11.
Very frustrating. Expensive piece of equipment that I can't use at this time.
Avid, please help.
  #32
Old 02-17-2014, 09:11 PM
clutch clutch is offline
Just wondering if you've tried putting the Artist mix on a static IP on its own subnet - IE a different IP range than any other network interfaces you may have.
Also, does it work reliably with PT 10.3.x or is this limited to PT11 for you?
I'm asking because I'm trying to find the most reliable combination of OS/PT/Eucon versions to use for a major project over multiple workstations.
He used to cut the grass...he was a very nice boy...
  #33
Old 02-17-2014, 10:09 PM
SoundEng1 SoundEng1 is offline
Not working here either! Please help!
  #34
Old 02-17-2014, 10:27 PM
Any chance you could copy the following text into the Terminal application and post the results?:
Code:
ifconfig | grep -v inactive | grep -B 7 active
This will list the active network interfaces and their IP addresses to determine if the device needs to be on its own subnet or not.
Also, is this PT11 or 10?
  #35
Old 02-18-2014, 09:02 PM
Thanks for the suggestions.
I have tried static IP in accordance with the written instructions in the Avid Knowledge Base IP: 10.0.0.1, Subnet 255.255.0.0. This did NOT work.
I want to be clear that my PC sees the Artist Mix and the Eucon software sees the Artist Mix. I can cause the Artist Mix to display info by clicking the button in the Eucon software.
The problem is only that PT11 doesn't see the Artist Mix. I never used PT10.x. I bought PT 11 and my post only applies to PT 11.
Haven't had a chance to try your ifconfig suggestion but will try it as soon as I have a moment. Just to be clear, I am using a PC, not a Mac. Does this request relate to Mac or PC?
  #36
Old 02-18-2014, 09:58 PM
Many apologies, the instructions are for a Mac.
You could use ipconfig instead of ifconfig in a shell in windows. You'll possibly just need to wade through a little more info without the grep command.
I'm assuming that when you set the static IP address on the artist mix that you put the ethernet port the controller is plugged into onto the same subnet...?
If your PC can see it, and the Eucon software can see it, it's probably not network though...
  #37
Old 02-19-2014, 04:34 PM
Yes, the adapter and the Artist Mix were using the same IP and Subnet
  #38
Old 02-19-2014, 04:39 PM
Sorry, the IP on the Artist Mix was incremented one after the controller. So the adapter/controller was 10.0.0.1 and the Artist Mix was 10.0.0.2. Both subnet 255.255.0.0.
  #39
Old 02-19-2014, 06:41 PM
That's the correct way to set it up. Sorry I can't be more help at the moment. Will keep thinking on it...
  #40
Old 02-19-2014, 09:02 PM
Hi. I hope you have been following this set of messages. Several people seem to be experiencing this "bad state". Your instructions seem to be for a Mac. Can you provide similar instructions for a PC or anything else that can help. I've got a brand spankin' new Artist Mix that has been a paper weight for 2 months.
Thank you.
ATTN JC. Eucon 2.7 + Artist Mix/Control via HUI Herbieoz Artist Series 5 01-09-2015 03:14 AM
Eucon, Artist Control and mouse. vinnyburns Artist Series 6 04-16-2014 07:43 PM
Artist Mix with Eucon 3 very sluggish mrtomcat Artist Series 0 10-03-2013 12:43 AM
Artist Control not working with Eucon 3 on OS X 10.8.4 Jerry Woolsey Artist Series 1 06-24-2013 02:21 AM
Artist Control check EUCON version on page 74 Audioartist Artist Series 1 04-18-2013 11:29 AM
