Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 11-04-2013, 12:42 AM
MEWCO MEWCO is offline
Default Focusrite 18i20
I have a new Focusrite (Scarlett) 18i20 Audio Interface, and keep getting this error message when trying to play back:
"Pro-Tools could not initialise the Focusrite USB 2.0 Audio Driver. Please make sure that the device has been configured correctly."
Anyone know if, 1. This unit is compatible? 2. if it is, what is the correct driver?
Moreover, must this driver be loaded before I install Pro-Tools 11?
Old 11-04-2013, 05:39 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Focusrite 18i20
I shouldn't matter if you install the driver before or after you install ProTools, so I don't think that is your issue.
What platform are you on; Windows or Mac?
Does the device show that it was installed properly, or can you use it in any other program?
Also make sure nothing else is using your interface before starting ProTools.
Will
System Details
Old 11-04-2013, 05:49 AM
EGS's Avatar
EGS EGS is offline
Welcome to the forum. Please read:
http://us.focusrite.com/downloads?pr...Scarlett+18i20
and also:
http://us.focusrite.com/answerbase/c...scarlett-18i20
Click for audio/video demo
Click for resume
Old 11-04-2013, 07:46 AM
No, Nothing else uses my interface. My laptop is used solely for running Pro-Tools and associated music/recording.
I am using Windows 8, 64-Bit.
Thanx
MW
Old 11-04-2013, 08:43 AM
JoelG's Avatar
JoelG JoelG is offline
Are you using the drivers/software from CD that came with it or downloading from Focusrite? I would recommend downloading the latest driver: http://global.focusrite.com/download...Scarlett+18i20 if you're not already on it as EGS posted.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 11-04-2013, 01:44 PM
Joel
Thanks guys!
I spoke to Focusrite in Guildford, England, today and they were most helpful.
He told me about the latest 1.6.1 and also to disable dynamic something or other on Pro-Tools session start up.
To be honest, I think Focusrite is the least of my problems!
I just wanna get Pro-Tools up and running, smoothly, where it dont take 20 seconds to add a new track nor go into 'Program Not Responding' every time I shut down!!!
Thanx!
Old 11-04-2013, 03:01 PM
dave911's Avatar
dave911 dave911 is offline
If you get the latest driver and it installs correctly but still gives this error try going to the windows control panel > sound and disabling your interface in both playback and record sections.
"In theory there is no difference between theory and practice. In practice there is." - Yogi Berra
Old 11-04-2013, 03:10 PM
junkgear's Avatar
Well, keep us posted. ProTools is working well with many ASIO interfaces, so hopefully the settings Focusrite suggested get you up and running.
BTW, the setting for Dynamic Plugin Processing can be found in the Playback Engine dialog.
Will
System Details
Old 11-04-2013, 09:02 PM
JCBigler's Avatar
JCBigler JCBigler is offline
I have an 18i20 and use PT 11 on Win7 64 bit.
I get this error when I open some older sessions that I recorded at 16/44.1k and the 18i20 is set to record at a different sample rate.
I have to close Protools and open the Scarlett Mix Control software and set the sample rate to the correct sample rate, then re open Protools. Usually works at that point.
Check your sample rates and make sure that the Scarlett Mix Control matches that of Protools, before you open the Protools session.
Also, I found that I can not connect my 18i20 to the USB 3.0 ports on my laptop. I have to connect it to the single USB 2.0 port, or I get the same error.
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB
2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio
Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
Old 11-05-2013, 04:48 AM
When I spoke to Focusrite they said make sure my USB is plugged into a USB 2.0 ('black' socket) rather than the USB 3.0 ('blue' socket).
Thanks for the advice.
I now have to do a complete de-install of Pro-Tools 11 and start again. Hopefully I get to delete everything and leave nothing lurking.
Bad enough trying to get used to horrible Windows 8 :-(
Pro Tools 11 with Focusrite Scarlett 18i20? hermonmusic Third Party Interfaces 24 06-27-2015 08:53 AM
Focusrite 18i20 won't detect when switching on Kollen.col Third Party Interfaces 11 03-26-2014 02:04 PM
Pro Tools 10 disconnects my Focusrite 18I20 Peter Warren Pro Tools 10 0 12-13-2013 12:31 AM
Focusrite 18i20 Pre amp with a Rode K2 and Nt1a microphone Kollen.col Third Party Interfaces 6 11-22-2013 04:38 AM
MIDI Keyboard, via Focusrite 18i20 Interface to PT 11 MEWCO MIDI 12 11-17-2013 01:33 PM
