treating a small room
Any good tips or places to look for info on treating a small home studio control room, "un-squaring" and surfacing?
5x5x2,5 meters. (15x15x8 feet) (Doesnt sound too good, right) I’ve been relying on filling it up w/furniture, hanging stuff on the walls and close-monitoring till now. Checked the half-empty room w/sinus tones and listening around - extreme cancellations and multiplications. The budget is, well, limited. Any help appreciated. Ben
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Re: treating a small room
Try going to www.auralex.com
They have lot's of good tips and info. |
HI BEN,
Don't worry about the square room! it s only the first few fundermentals that are a problem. The crap thing is all dimentions are multiples of each other. LISTED= 34 Hz = (to low for nearfields) 68 Hz = length , width ; problem 76 Hz = L&H,W&H,L&W 97 Hz = L&H,W&H 103 Hz = L,L&W&H ,W&L&H 124 Hz = LH,WH,LW 128 HZ = LWH 137 HZ = L,W,H 141 Hz = LH,LWH,WH,LW.LW.LW 145 Hz = LWH 153 Hz = LW,LW,LH,WH,WH 157 Hz = LWH,LWH,LWH 168 Hz = LWH,LWH 172 Hz = LH,LW,WH 175 Hz = LWH 185 Hz = LWH,LWH 197 Hz = WH 206 Hz = H,LWH & Up to 250Hz is only real problem area which can be fixed with a wide Que panel resonator (see studio acoustic book for design,easy!) The rest can be fixed with 1 & 1/2" dacron wool(the stuff in pillows) suspended out from the walls 4 inches away (use your imagination!) This will kill all problems down to 125 Hz The ceiling also needs the same treatment. You only need to loose 4" all the way round the room & 8" at the rear for the resonator to fix all your sonic grief! Dont worry square rooms are easy to calculate the modes for. Email me if you want specific details & I can talk you through the process. Best regards Michael EarthMedia Studios [email protected] P.S The materials cost under $1000 bucks, but you need to do all the labour youself. |
Finally acoustic treating my room. I have a few Q's | fenderrocker | General Discussion | 48 | 12-10-2010 12:43 AM |
Calibration in a small room... | joeyk | Post - Surround - Video | 3 | 05-08-2006 10:02 PM |
Treating a room for drums. | Travis Mitchell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-19-2004 02:32 AM |
Advice for treating MY room... | The Central Scrutinizer | General Discussion | 4 | 12-24-2003 04:06 AM |
Air Conditioning in a small room | benderbro | Tips & Tricks | 7 | 07-07-2001 08:10 PM |
