Old 02-06-2024, 06:12 PM
SteveWatkins SteveWatkins is offline
Default ModDelay III time value
When this plugin in sync'd to the session time, the value changes. If I manually type in a tempo in the transport, the tempo changes. These are the expected results.
However, if I tap tempo, the time will not change on the plugin even though the session time changes. How can I tie the tap tempt time to the plugin value?
Old 02-20-2024, 08:29 AM
Default Re: ModDelay III time value
Not sure you can. Maybe try a delay plugin that includes a Tap feature(Waves H-Delay is one). Are you trying for something that does NOT match the song tempo? In that case, I would disable the sync function and adjust the time manually, or change the note value(maybe something you are not aware of?). If you describe the end goal, maybe someone will have the perfect solution
ModDelay 3 Bug introduced in 10.3.4 Again? Dot Pro Tools 10 0 04-23-2013 04:53 PM
ModDelay III losing settings Giannis Pro Tools 10 2 07-04-2012 02:45 PM
Clip Gain won’t update in real time during playback on Elastic Time tracks yanos macOS 0 06-03-2012 03:48 PM
Bug Report ModDelay 3 Dot Pro Tools 10 3 05-30-2012 06:00 PM
Delay Time on ModDelay 3 !@#$% KingFish Pro Tools 10 0 05-07-2012 03:51 PM
