Old 01-28-2024, 07:34 AM
Glide Glide is offline
Default The Current Playback engine does not support a sample rate of 48 kHz
I am trying to open older Pro Tools sessions on PT 12.7.0 on a Windows 11 machine and Digi 003. I keep getting "The Current Playback engine does not support a sample rate of 48 kHz" error.
I've searched the web and the forums and I cannot find the reason why.
I've tried to set up a new session at 48 thinking I may be able to just import them, but it will not let me set it at 48.
I've gone to setup / playback engine and my only options are Windows Audio device and Digidesign FW003.
Will PT 12 not load previous sessions or is it possibly a limitation of the Digi 003?
Thank you for any help.
Old 01-28-2024, 07:41 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: The Current Playback engine does not support a sample rate of 48 kHz
Compatibility info here.
Janne
Old 01-28-2024, 07:50 AM
Thank you.
For anyone experiencing this 48kHz error I just found the fix.
The problem is that you need to be sure that in Windows the Digi 003 is not the default audio device.
If you change the windows default audio device to the sound card on your system you will be able to enable 48kHz and then you can load the earlier Pro Tools sessions.
Old 01-29-2024, 11:59 AM
albee1952 albee1952 is online now
Originally Posted by Glide View Post
Thank you.
Good detective work. This is well-known that all Windows systems USUALLY need this(there are a few exceptions, but the 003 is not one of them)
the current playback engine does not support a sample rate of 44.1 khz Katsull macOS 2 10-23-2018 09:20 AM
the current playback engine does not support a sample rate of 44.1 khz bzerk Pro Tools 12 11 05-03-2015 07:13 PM
The current playback engine does not support a sample rate of 48 kHz. allegrarc macOS 9 11-27-2014 09:43 PM
the current playback engine does not support a sample rate of 47.9 kHz mikevarela Post - Surround - Video 3 03-30-2013 09:26 AM
The current playback engine does not support a sample rate of 44.1 khz murdafew Pro Tools M-Powered (Win) 4 05-14-2010 03:21 AM
