Old 12-07-2012, 09:52 AM
johnjm22 johnjm22 is offline
Default Anyone Having Success With 1155 Socket?
Title says it all. If you have a solid/stable Pro Tools DAW on an 1155 socket CPU/MOBO I'd like to hear about it.
I ordered parts for my new LGA 1155 P67 build yesterday. I should have done more research first, because after reading this forum, I realize that 1155 isn't the best choice, but I'm curious to know if anyone is having success with this type of setup.
Old 12-07-2012, 12:42 PM
Default Re: Anyone Having Success With 1155 Socket?
Sure wish you had asked BEFORE you ordered the parts. My 1155(2500K) on an Asus P8P67 was and is a total bust for Po Tools. But it makes a real nice office machine There are only 2 builds I would consider for Pro Tools today. i7 socket 1366/X58mobo/Triple-channel RAM( modest budget) and i7 socket 2011/X79 mobo/Quad channel RAM(best). These 2 setups are solid, compatible and everything else you need. Anything else(1155, 1156, AMD) is a crapshoot.
Having said that, maybe your rig would kick butt as a hackintosh?(that's why I chose those parts, but I never got the final step to take so I gave up after 4 days of fussing and loaded Windows 7 x64).
Old 12-07-2012, 01:54 PM
miketeachesclass miketeachesclass is offline
Default
I'm using an i7 3770k and its working perfectly in a hackintosh.
Old 12-07-2012, 01:55 PM
Niilo Nuori's Avatar
Niilo Nuori Niilo Nuori is offline
I have been using a PC build around Gigabyte GA-Z68X-UD3H-B3 (i7 2600K cpu) and it seems to work just fine and it has LGA1155 socket.
I am interested in knowing why this should not work?
__________________________________________________ _______________________________________
Intel i7-2600K @ 3.40GHz + GigaByte Z68X-UD3H-B3 + Noctua NH U12P SE2 + 32GB + EVGA GTX 950 SC+
Windows 10 Professional x64 + 4K Monitor + RME 800
StudioOne + Cubase (+ Pro Tools for simpler old stuff)
Old 12-07-2012, 02:15 PM
Dism Dism is offline
1155s have on die GPUs. Since integrated graphics are not compatible with Pro Tools, it's not a recommended setup. However, many motherboards do have well managed switching and options to disable completely.
On the flip side, the 1155 makes a very GOOD hackintosh/customac setup because most Macs run the 1155 chipset.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 12-07-2012, 03:22 PM
I didn't say it would NOT work. I said its a crapshoot. If you like to gamble, roll the dice. If you want the sure thing........
Old 12-07-2012, 07:57 PM
OK, thanks, makes sense. Naturally the first thing I did when building this one was to turn the integrated graphics off (BIOS has all the switches) and installed a separate PCI graphics card. Seems to work with no problems at least with my setup.
Old 12-08-2012, 03:36 PM
Thanks for the replies.
I'm not interested in Hackentosh's. This will be a Windows based DAW.
It turns out that the MOBO I ordered was D.O.A so I sent it back. Since Niilo Nuori is having success with the Gigabyte GA-Z68X-UD3H-B3, and the RAM I have just so happens to be on its QVL, that's the MOBO I'll pick up for my replacement.
Anyone else out there running PT on a Windows based LGA 1155 machine?
Old 12-08-2012, 03:37 PM
How heavy are the sessions that you're running? (track count, plugins, virtual instruments, sample rate ect.)
I7 3770k 1155 Success Trinibad1 Windows 0 03-10-2013 03:29 PM
what chipset works with 1155 socket? raytravel Windows 16 09-07-2012 05:52 AM
Any MB with 1155 socket that can support original PCI HD cards? David Sandwisch Pro Tools TDM Systems (Win) 53 06-27-2012 08:00 PM
Anyone with success with AMD x2 AMs socket? albee1952 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 06-14-2007 01:01 PM
P-4 systems, Socket 423 or Socket 478?? Rudger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-25-2002 10:25 PM
