profire 610 -> adding Eleven Rack
I have the ProFire 610 and run mpowered 8.
I want to get an Eleven Rack. Does this mean I'll have to run LE? If so, will I be able to use the 610 still? Am I going to end up with 2 systems that don't work together? Thanks Russell |
Re: profire 610 -> adding Eleven Rack
You can use it with your ProFire, you would just connect it via analog or digital IO - the USB connection only sends control data.
Are there any limitations when using Eleven Rack with Pro Tools HD or MP? Answer: When used with HD or MP as the main audio engine, the Eleven Rack USB audio streams are not available inside of Pro Tools. The Eleven Rack control window is still fully functional for controlling the device, and you can route the digital I/O or other analog I/O to your HD or MP system for recording and re-amping. |
Differences Between Eleven Rack & Eleven Plugin | Becharax | Eleven Rack | 15 | 10-16-2015 06:07 PM |
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? | Rongpat | Eleven Rack | 8 | 02-11-2014 07:42 AM |
Some experimental tracks using Eleven rack and Eleven RTAS | kittybite | Eleven Rack | 4 | 06-18-2013 12:18 AM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Eleven Rack and Eleven Rack control window not matching | 11R Newbie | Eleven Rack | 3 | 04-18-2012 06:07 PM |
