Old 11-07-2006, 07:49 AM
crizdee's Avatar
crizdee crizdee is offline
Default shortcut for page scroll please!
can we please have a shortcut for page scroll on/off!
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-07-2006, 08:08 AM
musiceditorcouk musiceditorcouk is offline
Default Re: shortcut for page scroll please!
Seconded - am currently in a dubb where the mixer would like to view continuous scroll whereas I prefer to edit with page scroll - faffing about changing each time with the mouse is a pain.
Tony
Old 11-07-2006, 08:54 AM
ProTooler ProTooler is offline
An EXCELLENT suggestion!
Have a great day.....
Bill
Mac Mini (2019)
3.2 Ghz - 6 Core i7
Mojave with 64 GB RAM
PT Ultimate (2019.10)
Motu 16a
C/24 Control Surface
Old 11-07-2006, 01:46 PM
rinky rinky is offline
Aye Aye to that!!!
PT Ultimate 2024.3
PT HDX
MacPro 7,1 (Intel)
16 Core
96 GB ram
macOS Ventura 13.4
Somehow, musicians are now technicians!
Old 11-07-2006, 02:58 PM
soundthinker soundthinker is offline
Hopefully Digidesign will give us complete keyboard mapping soon.
But until then, you can add your own keyboard shortcuts:
http://docs.info.apple.com/article.html?artnum=152140
http://david.narrabilis.com/2006/03/...-mac-os-x-103/
I use them for exactly this reason. I also had Import Session Data and Bounce to Disk shortcuts among others before moving to PT7.
/jim
James Slanger
HD3 Accel PT9HD
Old 11-07-2006, 08:23 PM
Chris Coleman Chris Coleman is offline
I can't stand editing with page scroll on - many times, I'll be listening to one spot while zooming in for a closer look in another...
So, I keep it off and when I need to catch up to the play head, I hit the down arrow then right arrow in quick succession.
It's not rocket surgery
Old 11-08-2006, 01:43 AM
Jim you are a genius - I've set up a pair of shortcuts ctrl~ and alt~ to select page and continuous via the apple shortcuts setup which does the trick...
...and also one for region name toggle on/off!! I'm loving this
thank you!
Tony
Old 11-08-2006, 01:58 AM
crizdee's Avatar
thank you!
Tony
How did you manage to get these commands without there being any key sequence for these functions!!? reading the creating custom key commands info, it seems like a function must have a key sequence to be able to put it in the custom keys!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-08-2006, 02:05 AM
No no - click on the David Narabillis link - much more informative than the apple one:
Do the following:
1. Quit Pro-Tools.
2. In system prefs, click keyboard and mouse
3. Click the + (add) button at the bottom of the window
4. In the window that drops down, find your pro-tools app in Application (via other at the bottom of the list because PT is contained within a subfolder in the apps folder)
5. In Menu title - enter the EXACT name of the command, caps and all - for example, for page scroll in PT7.1: simply type: Page
6. For keyboard shortcut, type the shortcut you want (has to be with apple, shift, ctrl or alt.
7. Click add...
open PT and viola - its ace - you'll even see the shortcut that you've selected next to page scroll to remind you what it is.
Where this will not help of course, is if there is a menu command that is exactly the same as another in another menu as you can't specify paths. For example the menu item "assignments" appears in both view > sends A-E and view > sends F-J, so you wouldn't be able to set a shortcut for that (would you want to!?)
Hope this helps
Tony
Old 11-08-2006, 05:52 AM
crizdee's Avatar
Hi Tony,
Thanks for the help, i got it to work ok, unfortunately there are 2 commands in PT for None so i couldn't turn scrolling off without loosing all the rulers which also has a command of None!! so although i could set 1 for page to turn page scroll on i couldn't set 1 for off!!
Chris
Producer, Engineer,
www.ukmastering.com
003 bug on page scroll rainsong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-09-2008 01:08 PM
Page Scroll - why no shortcuts gonzolagonda Pro Tools TDM Systems (Mac) 5 12-06-2006 08:34 AM
6.9 Page Scroll During Playback? blairl Pro Tools TDM Systems (Mac) 4 04-20-2005 03:22 PM
page scroll during playback songman Pro Tools TDM Systems (Mac) 0 12-31-2003 01:42 AM
Page scroll during playback Avid Pro Tools TDM Systems (Mac) 4 02-25-2001 10:28 PM
