Old 07-10-2006, 11:56 AM
colombianmike colombianmike is offline
Default Mid data transfer
Whoever can help,
This is my set up: I have the MPC 2000 with my Triton LE hooked up with Midi cables. Audio cables for both are hooked up to my mixer that is hooked up to the Mbox 2. What I want to do is create my sequences in the MPC (using the triton midi notes) and transfer the midi data used in the MPC into Pro tools as midi notes for each track. I have my MPC and Triton hooked up fine, but how do I get that data over to Pro tools?
Help will be much appreciated.
Old 07-10-2006, 12:59 PM
spkguitar's Avatar
Default Re: Mid data transfer
Save the data on the MPC as a .mid file, transfer it to the PC on a floppy, and then import the .mid file into Pro Tools. Once in Pro Tools, you will have to assign the output of each individual MIDI track to the device that you are triggerring with it (triton, mpc), but that's about it.
Old 07-11-2006, 07:20 AM
Default Re: Midi data transfer
I was successful and it did work. I appreciate the help. I guess the reason I wanted to find these things out are because I want to find out which hardware will be the master. I'm going to stick with the MPC as the building block and just smooth out the tracks in pro-tools.
Cool,
Mike B.
MIDI data transfer too Pro-Tools from Ableton Live? bms9nmh MIDI 3 03-16-2009 04:35 AM
not all of my headphone mixes transfer when using import session data paulreed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-10-2008 07:42 AM
Transfer data to a new hard drive PrivateStock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-06-2002 07:13 AM
data transfer ???? with Japan calden 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-18-2000 08:05 AM
[Q] DiskI/O data transfer rate in finder Gakuji Pro Tools TDM Systems (Mac) 0 10-21-1999 01:26 PM
