Reducing computer noise
Does anyone know of glass rack doors or any other way of cutting down on the computer and drive noise in the studio? By the time you have the cpu and a stack of cd, tape and hard drives there's a true annoyance. I have the cpu below the console and the removeable drives above (they could go below if there was a way to cut down the noise) Any ideas
thanks |
Re: Reducing computer noise
awhile ago there was a thread where someone was talking about a box that had built in (quiet) ventilation fans as well as sound insulation. Of course, I can't remember for the life of me what that device is called, but I figured I'd bounce this to top and hopefully someone out there will remember.
It was me...I simply build a box around the computer using 3/4 inch thick particle board, drywall screws and "liquid nails" glue with a piano-hinged door on the front...I design it so that the computers' fans move all the air by gasketing the computer in appropriate places (using self-sticking type door-foam gasket strip from the hardware store) within the box and providing labyrinth-like passages for the air..air will go around corners easily, sound will not. They turn out really quiet, and take an investment of about two hours and a sheet of particle board & some hardware.
Here's a typical drawing I did for another guy, just to give you the idea.... http://www.heartmagic.com/CPUquietBox.jpg |
If you can put an air conditioning duct into the box, you can build one with 1/2" plywood lined on the inside with corning microlite covered with cloth, then just hang a hinged door on the front. I'm sure someone probably makes the "studio" computer housing if you want to spend some money. How I got around the noise problem is by getting the Geffen systems extender boxes which allowed me to put my CPU 50 feet away in another room. I'm using a 9600/350 and have never had a problem with it. I don't know if they have a USB version out yet, or if you even need an extender for USB, but it helped with the monitors and apple serial issues.
Rick Sanchez http://www.posthastemedia.com MacPro 2x2.66 GHz Dual Core "WoodCrest" Mac OSX 10.5.8 / 4 Gig Ram ProTools 8.0.4 Digidesign/Magma PE6NE-I upgraded 6 slot expansion chassis. (Host card in Slot 2 of MacPro) HD3 Accel BlackMagic Decklink Studio 2 (In Slot 3 of MacPro) SurCode / Dolby Media Meter 2 Izotope RX2 Advanced / Sonic NoNoise Waves Platinum 7.x / Serato PitchnTime Melodyne Studio / Altiverb XL / Speakerphone KOMPLETE 7 EQuality / Massey L2007 TC MasterX |
I've used 6 foot monitor and ADB extension cables with success for the past five years on desktop Power Macs. It gives just enough length to put the comp in an adjacent room. I've noticed a little bit of monitor aliasing but absolutely no probs with Waves dongles or OS....plan on doing alot of walking if you are burning CD's or using periphs.
I like Gary's CPU quiet box drawing and may give that a try! |
somebody here in Nashville has started building quiet racks. I think they call them "isobox", but I'm not sure. Here's the number for our pro dealer who sells them and would know if there are any others available. I plan on moving my system into a quiet rack when I know it doesn't need to be moved anymore. Good luck
--Shawn Here's my guy Frank Conway, Audio One (615)341-0056 |
computer in the next room gets my vote
for lowest possible noise floor, monitor extentions affect image quality however... i am suspicious of "isobox" as it has fan noise of it's own to deal with
serious munter |
Here's the site for the place in Tennessee. Thier stuff looks great. As for the fan noise, thier are fans designed to operate quietly: You just won't see one on a hard drive. I'm a fan of having the computer in the control room for access to the internal CD, and for hard reboots (especially for G4 OS9 users!) The geffen system is a good idea also, but what if you have two monitors?
http://www.custom-consoles.com/isobox.htm enjoy! ps |
actually, the isobox's fans are isolated as well. the first time i saw one, it had a computer, two glyph trip racks (which sound like jet engines), expansion chasis, and ups system in it. I was amazed at how quiet it was. It was a lot quieter than the current config my system is in, which is in the next room. More noise comes thru the hole the cables are passing thru than comes out of the isobox. food for thought.
--Shawn |
--Shawn |
strategy for reducing noise?? | SteveSZ | Pro Tools TDM Systems (Mac) | 3 | 06-06-2009 01:43 PM |
Reducing White Noise on Old Recordings?? | xfourninetwox | General Discussion | 3 | 06-04-2009 10:48 AM |
Need help reducing guitar amp noise | michaelmouse | Tips & Tricks | 7 | 03-19-2005 11:44 AM |
Whats the best fan for reducing PC Noise | rcourell1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-28-2004 12:05 AM |
Suggestions for reducing headphone noise | GRIP22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-29-2003 04:53 PM |
