Old 12-03-2020, 03:03 AM
belasoul belasoul is offline
Default Time Shift Plug-In fps change
What do you think about the results of the Avid "Time Shift" (stock) Plug_in performing a Film to PAL (Maintain Pitch) +4,1667% change on a 5.1 theatrical Mix (classic live action film)?
Would you do that? Or do you recommend another workflow?
Béla Brandes | www.bbsounddesign.de
Old 12-03-2020, 03:06 AM
tom_lowe tom_lowe is offline
Default Re: Time Shift Plug-In fps change
Get Elastique Pitch and/or Elastique AAX. Process on stems, not a full mix.
Old 12-03-2020, 03:48 AM
I wouldn't use any maintain-pitch-algos (time-stretch or squeeze) in one run. Almost all of them alter sync in favour of sound quality. Resulting in a rubbery looking sync even when the file itself has the correct length.
First do a straight SRC (with no pitch correction) to maintain 100% sync. Create a new session and import the stems with SRC and the preset that applies to your setup. This will "varispeed" SRC the stems to the desired length which will be 100% sync.
After that do a pass of pitch correction to taste (Elastique or TimeFactory II are the best IMO). Often you can get away with less than the 100% depending on the stem ans type of content. Depending on the project often correcting the music and DX stem is fine.
Old 12-03-2020, 03:57 AM
Ok. Thanks guys!
@Frank: What tool would you recommend for the SRC and the later pitch correction?
Old 12-03-2020, 05:48 AM
eh...i guess should have been Frame Rate Correction..so FRC
Old 12-03-2020, 05:52 AM
Elastique AAX will take care of everything, but do it in 2 separate internal processes, but the end user it looks like one process.
There's also Elastique V2 which only deals with pitch. For SRC fisrt import your stems, but tell Pro Tools that the files are 46,080 Hz (24 - 25) or 50,000 Hz (25 - 24). This is assuming your originals are 48KHz. That will take care of the speed change.
Then use Elastique to correct the pitch.
Old 12-03-2020, 05:56 AM
Ok. Thanks guys!
I wrote that in my last post.
1) import stems (import session data or import file) with SRC option on and select preset and check sync with head and tail pops.
2) correct pitch to taste with whatever you like best. Elastique and TimeFactoryII are proven workhorses for that that don't mess up phase and sync.
I prefer the 2-step process as I always have one 100% bang-on sync reference to compare to if I need to go back or compare the result.
Ah that's good to know. Thanks Tom.
Old 12-03-2020, 06:03 AM
I'm *almost* certain that's how it works anyway - can try and find the documentation.
Old 12-03-2020, 07:00 AM
Great Guys. Thanks for explaining!
HTML code is On
Where is New Time Shift Plug-in xxfunkxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-24-2007 08:06 AM
Explanation for FORMANT shift in Time Shift Plug In, please! Darney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-13-2007 11:00 AM
New Time Shift Plug-In MusoPro Post - Surround - Video 1 09-19-2006 11:43 AM
time shift plug-in CalebB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-28-2006 03:30 PM
Time Shift to change tempo??? delwin Pro Tools TDM Systems (Win) 2 08-23-2006 11:39 PM
