Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 01-21-2021, 08:47 AM
senghor senghor is offline
Default mono -> stereo. How to do it in PT?
Hi!
I want to make a mono track to a stereo track. I know it is possible in PT, but I don't know how to make it!
Thanks for your replies!
Win11 Pro
Intel i7-12700K @3,6GHz, RAM 32GB
UAD Apollo and pre-amps, Pro Tools 2023
lots of plugins
Old 01-21-2021, 08:58 AM
Default Re: mono -> stereo. How to do it in PT?
You can't actually change an existing track from mono to stereo unless you put a mono->stereo plugin on it. But then only the output is stereo, not the input/source. What exactly is it that you're trying to do?
Scott Gatteño
Old 01-21-2021, 08:59 AM
Dan IceWood Dan IceWood is offline
what version are you using?
Old 01-21-2021, 09:33 AM
pt 2020.12
Win11 Pro
lots of plugins
Old 01-21-2021, 09:37 AM
Wolfgang Eller Wolfgang Eller is offline
Copy the mono track, name one .L and the other one .R and drop it on a stereo track.
www.srs-mastering.de
Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface.
Old 01-21-2021, 12:23 PM
Duplicating a mono track does not make it stereo. It makes dual mono and will not sound any different than a single mono track(except louder when the 2 identical signals combine). Its still down to the question about what the goal is? Some general stuff to consider"
1-a mono SOURCE(like a bass guitar, snare drum or a vocal) is a mono signal, and belongs on a mono track.
2-there are a few ways to create a stereo-sound(not real stereo, but an effect) from a mono track, such as using a mono/stereo reverb/delay/chorus plugin(whether this is good or bad is totally up to the listener)
3-down to the most basic( I have no idea of your skill/knowledge level and no offense is ever intended); its perfectly normal to use many(or even all) mono audio tracks in a recording, and use pan controls to spread things across the stereo sound field. Once again, the source dictates whether the recording should be mono or stereo
4-another way to give "space" or "spread" to a mono track is to pan it to one side and send(using a send) to a mono AUX track with a mono reverb, panning the reverb to the opposite side.
If you describe the desired result, I'm sure you'll get multiple ideas on how to get there
Old 01-21-2021, 12:52 PM
The challenge is not to make a mono file stereo but to place a mono file onto a stereo track.
Old 01-21-2021, 05:43 PM
This was a great idea, but I can't make it work!
Win11 Pro
lots of plugins
Old 01-21-2021, 06:03 PM
I want to give the vocal track a little spread. I can send it to a stereo bus, I can duplicate the track. But I want a single dual mono track. Why? Because I want to save tracks. Just a single track instead of two (bus or double track).
Win11 Pro
lots of plugins
Old 01-21-2021, 06:19 PM
Sardi Sardi is offline
You need to consolidate the mono track, duplicate it, consolidate the duplicate, then rename the original with .L and the duplicate with .R
Now you should have ‘name of vocal track’ appear as a *stereo file consisting of the left and right sides. Create a stereo track and drag that to the timeline. Alternatively, you should be able to select the L + R tracks and drag it to the newly created stereo track. Once selected, it should highlight the *stereo track in the clip list.
*stereo - as pointed out above, it’s actually dual mono.
making mono track into stereo or double mono in PT7LE VeganMuso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-02-2012 05:36 AM
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 07:33 PM
Stereo Aux vs Mono Aux and Turning that Mono into stereo via a stereo Plugin JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-14-2010 09:01 AM
Mono/stereo Stereo mono..... What happen here ? jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-18-2004 09:28 AM
stereo file to mono and mono too stereo ? surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-19-2003 07:52 PM
