Old 06-03-2019, 10:17 AM
Funk-O-Meter Funk-O-Meter is offline
Default Can't get multiple audio outputs working in Blue Cat Patchwork.
I need help getting multiple audio outputs working in Bluecat Patchwork. I'm trying to split outputs from some old VI's out onto separate tracks for printing. I can set up the busses inside the VI but when I look in the input menu of audio tracks to select the VI's outputs the "plug-in" submenu is greyed out.
I've suspect I've not got things set up properly inside Patchwork but I'm at a loss.
Help?
I'm on PT 2019, Patchwork 2.something.
Old 06-03-2019, 01:26 PM
Default Re: Can't get multiple audio outputs working in Blue Cat Patchwork.
Can one of the moderators merge this thread with the other identical one here? http://duc.avid.com/showthread.php?t=405044
But to answer the question are you using the synth version of Patchwork? There's two versions one of which is specifically meant to host vi's. You'll also want to make sure you're running the latest version of Patchwork.
Jack
QAPLA!
Old 06-03-2019, 01:35 PM
Ironically I just discovered the two separate versions just now and came here to report on my little victory.
I was indeed using the plugin version from the "other" submenu in my plugins list whereas I needed to use the synth version from the "instruments" submenu.
Thanks folks!
Blue Cat Audio PatchWork 2.1 Released - Adds 25 Built-in FX, Zoomable GUI and more... bluecataudio AAX Plug-ins 15 11-27-2017 08:10 AM
Blue Cat Audio Patchwork Pro Tools 8LE ChristiaanU Getting Started 4 01-06-2016 08:43 AM
Blue Cat's PatchWork 1.7 is here, with ext. sidechain input, aux outputs and more bluecataudio AAX Plug-ins 30 04-22-2015 07:22 AM
Blue Cat's PatchWork Updated to v1.62, with brand new Light Blue UI Theme bluecataudio AAX Plug-ins 5 01-10-2015 12:41 AM
