  #31
Old 04-14-2019, 03:41 AM
rprovideo rprovideo is offline
Default Re: Dock monitor control
Has this happened? I’m holding back on buying an xmon for monitoring only because of this.
Thanks
  #32
Old 04-15-2019, 11:14 AM
EddieJones's Avatar
EddieJones EddieJones is online now
We showed this at the NAB show last week. The release is now 19.5 due in a few weeks.
File Type: jpg EUCON 2018.12 PTC_monitor_with_Mon_Sources.jpg (46.8 KB, 0 views)
  #33
Old 04-16-2019, 03:54 AM
Jamie Mac Jamie Mac is offline
Will this also work with an xmon or only with the MTRX?
  #34
Old 04-16-2019, 06:59 PM
EddieJones's Avatar
It will work with any EUCON monitoring, MTRX, XMON, PT Master Fader, Nuendo, Cubase, Pyramix, SMP2(if anyone is still using it)
  #35
Old 05-23-2019, 05:35 AM
Matt82au Matt82au is offline
I finally tried to have a crack at getting this running with an old blue X-Mon (our d-command died, and have been hoping to get this into action).
I followed the guide posted on the DUC here...
http://duc.avid.com/showthread.php?t=400839
No luck, so checked our old Xmon cable and noticed Pin 11, 12, 3 and 4 had no through continuity, which seemed at odds to this guide. I then found this post on Gearslutz....
https://www.gearslutz.com/board/high...rol-cable.html
This seems to confirm my thoughts, and I tried adjusting the Midi In and Out pins to 10 & 2, and 9 & 1. I then had MIDI information in and out of the X-Mon which I could see flashing when the iPad app was adjusting signals, BUT...
The X-Mon remained frozen on Mute, and could not unmute through any means (front button, the apple XMON app, or the iPad.)
I am a bit stuck about what to do here, so wanted to ensure that the Blue X-Mon is indeed supported, if there is any things to be aware of regarding pin layout discrepancy or other things to be aware of.
Thanks for your help! My Apogee Symphony just went down today as I was having a crack at this, so I am now without and volume control, so any advice would be amazing.
Best,
Matt
Matt Perrott
Sound Designer and Engineer
Sydney, Australia
  #36
Old 05-23-2019, 09:06 AM
EddieJones's Avatar
It should work, the breakout cable on that DUC post is correct.
  #37
Old 05-23-2019, 10:36 PM
Ill look into it again on Monday, can you think of any reason why my old Xmon cable had no continuity on pins 11 - 11, 12 - 12, 3 - 3, 4 - 4.
Thanks for the reply!
Matt Perrott
Sydney, Australia
  #38
Old 06-09-2019, 01:10 PM
sjcollins92 sjcollins92 is offline
I Have 4 artist mix, ipad dock, and my xmon connected and locked, i wanted to know am i able to have monitoring in focus as well as protools 2019.5 without have to switch back in forth between apps............. I want to be able to push monitoring and my xmon is there, as well push mixer,channel,softkeys, and those functions show up............ as of now the only way is switching apps................... can anyone help me on this. Thanks
  #39
Old 06-09-2019, 02:24 PM
BScout BScout is offline
Assign tab in Eucontrol.
Put the XMon application in focus and then lock "Monitor and Control Room" on the Assign tab.
  #40
Old 06-09-2019, 02:32 PM
Thanks for responding, I have done that when i put XMON in focus XMON is showing, but if i push Mixer,Tracks,Channel,or soft keys its blank and im in protools all faders are down until i unlock xmon in the assign tab
Can you use the MC Control with S3 instead of the Dock? KeyplayerG Avid S1, S3, Dock and Control App 4 01-11-2018 04:34 PM
Dock with Artist Control Sugarfree Avid S1, S3, Dock and Control App 2 09-21-2017 05:31 AM
Control App/Dock ques: Custom pan jkess Avid S1, S3, Dock and Control App 1 08-27-2017 09:45 PM
Is The Dock really any better than the MC Control? KeyplayerG Artist Series 7 04-28-2017 03:51 PM
Is The Dock really any better than the MC Control? KeyplayerG Avid S1, S3, Dock and Control App 1 04-24-2017 05:42 PM
