AAE-error-1125 was encountered.
For some time i just getting this error during launching protools.
Protools 11.3.2 HD HD i/o firmware 5.5 I almost tried everything, total new osx ( 10.10.5 ) Fresh install protools 11.3.2 + HD driver 11.3.2 Macbook pro Retina,16GB Magma chassis 3T also tried new digilink cable. Installed osx from the ground.... Nothing is helping... Gonna try fresh install Mavericks. Please any help....
Jimmy Makhaisingh Producer Mix/Mastering Engineer JimJam Studio iMac (Retina 5K, 27-inch, Late 2015) PT11HD HDX /HD i/o Magma Thunderbolt 2.0 Chasis 3T Manley Vari-Mu / MPassive Mastering version Sonnox bundle / McDsp / FabFilter / |
Re: AAE-error-1125 was encountered.
Jimmy, Did you ever figure this out?
I'm getting the same AAE -1125 error but only on a couple of my interfaces. My HD IO is fine but my two Aurora 16's won't work at all and have latest firmware installed. Wondering if you ever got to the bottom of the problem? Thanks Sean |
I have this error when my Aurora 16 is connected. If I run Digitest, the HDX card passes if the Aurora is not connected, but fails when it it.
Mac Pro 2008, Mac Os 10.9.5, PT HDX 12.7.1, Aurora firmware 28, LT-HD firmware 11 |
I am getting the AAE ERROR -1125 too. It usually comes when I switch sessions or boot from scratch. Restarting has fixed the issue for a few weeks but now it seems more stubborn.
My hardware in this current state is three Lynx aurora's 16's with an HDX card. I'm using Sierra on a souped up 12 core Mac Pro cheese grater with 64 gigs of ram and PT 12.8.2. (Same issue with 12.8.1 and 12.7.x) As far as the digitest and my experience.....it always gives errors for third party units. So I use the hardware config window to see if a third party interface is working. With the the aurora's they just show up as HDio's and then I know they are talking to the Hdx properly. I talked to Paul at Lynx tech support in mid December (2017)and he indicated that they would have a firmware update for their interfaces any minute. I'm hoping it addresses this but it sounded more like it was not a Digilink update but a Mac OS issue and that was doing weird things to the clock rate when Pro Tools was not on and the Mac Os was defaulting the clocks on the Auroras to 96k with out being asked. Sometimes accompanied with the crazy hash noise that another duc user mentioned in this thread....It came only from the second 17-32 interface that is in the secondary port hanging off the first Digilink pair. I intend to use more I/O in the coming weeks to integrate more analog I/O and a tape deck but have not liked the clocking behavior with more units. I'm considering another piece of hardware with more I/O plus Dante or Ravenna or AVB in the mix to remotely include the tape deck. Any input is welcome. Two questions. What is this I hear about needing a "Digilink license"? Also has anyone had positive or negative experience with latest HD driver that comes with Pro Tools 12.8.3. Thanks, Dan
Notable.com AfricanUnderground.com DemocracyinDakar.com NomadicWax.com |
Update: Found the Digilink license in my ilok account and added it to my ilok. Not sure what it has fixed or facilitated. Adjusting with the audio/midi sample rate to 96k(it defaults to 192) stops the explosive white noise that sometimes occurs when PT software is quit. Multiple restarts and dig pref tossing saves me from -1125 on start up. Its an awkward fix. Hoping for a better long term solution. Sent from my iPhone using Tapatalk Pro
So Getting back this problem....:confused
Back to this....
Help! I get the error 'pro tools has encountered an unrecognized component' error | gsmith135 | Windows | 10 | 12-17-2014 01:08 PM |
Error -1125... | ritch | Pro Tools TDM Systems (Mac) | 5 | 11-23-2010 06:37 AM |
Strange DAE -1125 error with Waves L316 Multimaximizer | gerax | Pro Tools TDM Systems (Win) | 1 | 04-06-2008 01:35 PM |
dae error -1125 when launching pt | Bryan Cook | Pro Tools TDM Systems (Mac) | 2 | 07-25-2007 08:05 AM |
DAE error was encountered while trying to connect (error #-7101 | Enis Presheva Jr. | Pro Tools TDM Systems (Mac) | 1 | 06-07-2001 12:45 AM |
