Old 08-25-2019, 10:38 AM
arche3's Avatar
arche3 arche3 is offline
Default Re: Considering going from HDN to HDX - Any downsides?
Originally Posted by Will Russell View Post
hi,
I mix all day everyday on HDX with both DSP and native plugins and totally love it! I also appreciate the low latency tracking and easy ability to overdub into a fully developed mix.
Agree
Sent from my SM-G975U using Tapatalk
Old 08-25-2019, 12:43 PM
BScout BScout is offline
hi,
Agree
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 08-26-2019, 03:10 PM
ghostwriter's Avatar
ghostwriter ghostwriter is offline
hi,
Me three, four, what are we up to?
A few of of my favorite toys: Retro Instruments 176 (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM 70, SPX90, Roland SDE 3000...
Old 08-26-2019, 11:36 PM
clonewar clonewar is offline
Originally Posted by Farhoof View Post
The internal mixer is always DSP, so using a native plugin on an aux will cause an added delay compared to your native setup. Even without mixing dsp plugs with native plugs, there is always a switch from dsp to native (when used on an aux, tracks are ok).
IIRC the delay is the length of your hardware buffer (settings).
Good to know, thanks. I don't think the additional delay would be an issue for mixing as long as it's properly compensated for, which I believe it should be?
Old 08-26-2019, 11:38 PM
Hi, welcome to the community.
First check your computer has enough power for the HDX cards
Thanks for the welcome! The HDX cards would be going into one of my HP Z820 workstations, which have a lot of available power. I think they are (or were when they were current) on Avid's approved workstation list.
Old 08-26-2019, 11:49 PM
Originally Posted by albee1952 View Post
Maybe the better question is: What's the upside? If you need more than 64 IO, then you have to weigh things out, but if 64 is enough IO, I'd stick with HDN. My last commercial studio had 48 IO and I never actually used it all up, even tracking 6-7 piece bands
Really the only upside for me right now is access to more than 64 I/O. I have a very smooth running HDN system now, and honestly it's kind of a bummer that I'll have to go to HDX2 to be able to use more I/O, but that's where I'm at. Assessing my I/O usage to stay on HDN is definitely one of the things I'm looking at. (printing hardware inserts, etc)
I could also move to Nuendo for mixing, I already have an RME MADI FX card and could add more MADI I/O, but I prefer mixing in PT and don't want to give up my D-Control.
Old 08-26-2019, 11:53 PM
hi,
Originally Posted by arche3 View Post
Agree
Originally Posted by BScout View Post
Agree
Thanks guys, I've read some negative things about HDX (negative is usually what comes up in forum/internet searches) so it's good to read the positive!
Old 08-29-2019, 06:29 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Yes and no, the delay will be compensated, but that will also introduce some fader lag, depending on where the delay is originating and where your mixing faders are.
Let's say you have some tracks you want to mix, and some aux plugin chain coming _after_ the tracks. Extra delay is added to the auxes. The delay compensation will actually play the audio track ahead of time to compensate the delay in the aux so the sound will reach the output in time. Your fader movement however (hand & ears) are responding to the sound output and written into the track that was played ahead of time. Protools obviously cannot see into the future so it can not initially playback the track including the mix decisions you are making on the spot. What you hear while mixing is your fader movement applied _after_ the compensated delay. When you stop the playback, your fader movement is also compensated and is now placed at the exact spot where you heard the sound, so when you playback the track again, including your just written fader movement, it will sound different though probably more like you intended.
E.g.; there is a quiet track with 1 short loud sound. There is 12.000 samples delay on the aux. You know when the loud sound is coming and you duck the track fader at exactly that sound. On your first run writing the fader movement, you will still hear the loud sound and will hear the quiet sound (12.000 samples after the loud sound) ducking. When you stop playback and the red fader movement is written into the track, you will see the ducking movement on exactly the loud sound. Next time you playback you will hear the loud sound ducking because Protools is now able to compensate your fader movement along with the track.
So it's really dependent on your session setup, your plugins, your mix workflows, etc, whether you are better off with fully native, hdx with native plugs or hdx with dsp plugs.
Personally I'm running HDX2 because I need the voices, and voice packs didn't exist back then. I don't need the IO (maybe at some point going Dolby Atmos). I prefer using dsp plugins on auxes but I have a bunch of native plugins running also. Even with native plugs my delays are not that terrible so I have no issues with fader lag. However, I would not invest into dsp anymore, I don't see any future in it the way things are right now.
What Are The Downsides Of Using Third Party Interfaces orbro Pro Tools 9 4 11-08-2010 04:49 PM
downsides to "low latency monitor" mode jacko32 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-16-2003 01:27 AM
Can this be done with success are there any downsides to this functionally STUDIO-DE-ARIEL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-20-2002 11:59 AM
