Old 03-16-2019, 10:36 AM
climber climber is offline
Default Auto Record Enable on MIDI Tracks
So if I select one or multiple MIDI tracks they are automatically RECORD ENABLED. I didn't use a controller keyboard for years, but now that I am I find this incredibly annoying. So this is just one of those "the way it is" things? I have an AKAI MPK249. Is there is no way to turn off this "feature"?
I have dome some searches and it seems that it's not a preference anywhere...
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 03-16-2019, 11:51 AM
Default Re: Auto Record Enable on MIDI Tracks
This shouldn't happen. With everything shutdown disconnect the Akai. Restart the computer and PT and try what you wrote above and see if they're still coming up record enabled. Don't say that it didn't happen before - just try what I write here. If the tracks are not automatically record enabled then that rules out PT.
Power down everything and reconnect the Akai. Go online and grab the free snoize MIDI monitor utility. Run it standalone. Open the disclosure arrow in the filter entry and unclick 'clock' under the real time heading. That will stop annoying clock messages. See what kind of messages come up from the Akai; without pressing anything on the Akai there shouldn't be anything.
What I'm getting at is that it may well be the Akai doing something it shouldn't.
Jack
QAPLA!
Old 03-16-2019, 03:34 PM
thanks Jack... I will give that a shot tonite or tomorrow
Al Hospers
Old 03-17-2019, 02:29 PM
clausiii's Avatar
clausiii clausiii is offline
Do you have „M-Audio Keyboard“ enabled in the Peripherals/MIDI Controllers dialog?
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 03-17-2019, 03:20 PM
yes
Al Hospers
Old 03-17-2019, 03:22 PM
this still happens even if my keyboard is disconnected and I restart PT. I will try un-enabling it in peripherals tonight & see if that changes things.
Al Hospers
Old 03-19-2019, 06:43 AM
I un-enabled my keyboard in the Peripherals tab and it doesn't enable auto-record on MIDI tracks.
the other issue with this happening is that when I'm editing a MIDI track it often pops up a dialog saying that I don't have an Input selected!
this feature is VERY annoying!!!!
Al Hospers
Old 03-19-2019, 07:05 AM
clausiii's Avatar
the idea behind the auto record Midi thing is to quickly switch between tracks with the M-Audio keyboard to play along without the need of a pause, switching things off and on...
the second thing is that if you have M-Audio keyboard enabled in the peripherals dialog, PT wants to record enable the track you select. The it has no input enabled, it tells you that, because PT can´t record enable a track without any input.
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 03-19-2019, 07:08 AM
clausiii's Avatar
if you don't need the special M-Audio keyboard features - "Hypercontrol" - then deactivate it in the Peripherals dialog. The keyboard will still work but you will not have features like plugin control (which is nice) or navigating through your session with the M-Audio keyboard.
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 03-23-2019, 04:11 PM
The interesting thing is that I have an Akai keyboard, and there is no Akai option. What should I use?
Al Hospers
Turn off Auto Record Enable Clicked Instrument Track? DrFord macOS 16 04-04-2023 05:47 AM
Record enable instrument tracks in midi editor Intransit Pro Tools TDM Systems (Mac) 8 09-22-2011 02:20 PM
Hey U Short Cut Pros. Auto Record Enable? Craiger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-27-2010 04:09 AM
Midi Tracks - how do I record enable mutliple midi tracks? ram1500 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-22-2007 04:32 AM
Auto Record Enable RMarkss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-10-2004 07:38 PM
