Old 01-30-2017, 10:51 AM
propower propower is offline
Default Grouped tracks - multiple playlist - comping - key commands not working as expected
I was editing a group of 3 tracks with 7 takes and found that the key command for going up and down the playlists (CTL + P, CTL + ; ) yielded unworkable results. The cursor would jump to the next track in the group rather than just going to the next playlist in the track I was using as the edit one.
Any one else seen this? Was i using the wrong Key Command?
PS - I so dearly wish that SOLO on the playlists would follow the edit cursor...
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT2019.x Orion Studio 2017, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
Old 01-30-2017, 11:38 AM
Drew Mazurek's Avatar
Default Re: Grouped tracks - multiple playlist - comping - key commands not working as expect
Lee,
Were these tracks grouped before of after they were recorded?
I have found PT to dead on with playlists PROVIDED the tracks were grouped before you ever record onto them.
The few times I've grouped them afterwards, it's been iffy.
www.drewmazurek.com
Old 01-30-2017, 12:10 PM
Grouped before
OK I did a test with 3 grouped tracks and 6 playlists
If you put the cursor in Lane 1 of the top track and hit "CTL + ;" the cursor moves correctly but the screen view jumps (putting the next track down in the center -*repetitive CTL + ; works smoothly but if you go CTL + P it jumps again putting the upper track at the top f the screen.
With 7 lanes zoomed to take up the height of the window it is jarring- to me.
Old 01-30-2017, 12:58 PM
Hmm, all seemed good here. I got all expected behavior I think. Unless I am missing something.
BTW, in command focus mode, you don't need the modifier.
www.drewmazurek.com//GroupPlaylists.gif
www.drewmazurek.com
Old 01-30-2017, 01:28 PM
Yes - now zoom your track 1 and all its playlists to fill the screen top to bottom and try it. You will find the off screen stuff jump in and out. I had a Mono track that was easy to focus on and 2 stereo ones that kept jumping into the screen...
Elastic Audio is Phase Shifting with Multiple Grouped Tracks soundfaithaudio Pro Tools 10 11 01-31-2015 12:42 PM
comping part from multiple tracks & viewlists wildhair Pro Tools 10 8 07-28-2012 03:31 PM
comping grouped tracks manyrains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-21-2012 06:12 AM
Comping multiple tracks that are in a group problem no-xplode macOS 1 01-25-2012 03:09 AM
View more than 1 playlist in PT9 for comping tracks Raoul23 Pro Tools 9 3 12-15-2010 09:45 AM
