Old 04-11-2007, 07:26 AM
Johanna Herr Johanna Herr is offline
Default Auto Backup not doing anything
Anyboby experience in this?
Even though auto backup is enabled (every 5 minutes, keep recent 10), nothing is happening, there is no auto backup-folder created nor is there anything backuping ("backing up"? however...) happening.
I did all the general troubleshooting routines (delete prefs, digi database folder, verify permissions etc...) but nothing helped. pretty bad once one is used to auto backup and after two hours of editing the system crashes without any autosaves...
System is a G4, OSX 10.4.9, PT7.2 cs2
Somebody around has a hint?
Thanx
Jo
Old 04-11-2007, 08:36 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Auto Backup not doing anything
Thanx
Jo
Is this happening on all sessions? or just one?? If on one session then try "save copy as" to start a new session.
Has this system been running ok till now? or is this a new install?
You definately trashed ALL the prefs!!
you definately trashed ALL the database files and the database folder in Mack HD/Library/app support/Digi!!
Finally uninstall Pro tools then re-install Pro tools. there's an uninstall facility in the Digidesign folder in applications/mack HD. try the safe uninstall, reboot the mac then re-install from your CD or web installer. this won't take long and it won't effect your third part plugins and non digi-rack plugins etc.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-11-2007, 03:47 PM
Andre Knecht Andre Knecht is offline
Just to dot the “i”, OSX 10.4.9 still isn’t qualified by Digi.
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
9.0.2 auto backup bug... mykhal c Windows 16 04-20-2011 10:37 PM
PT 7 & 8 Auto Backup BUG - Beware 25ghosts Pro Tools TDM Systems (Mac) 8 10-13-2009 10:10 AM
Auto backup error??? protuser 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-13-2006 12:54 PM
Auto Backup question Don Geppert Pro Tools TDM Systems (Mac) 1 10-29-2006 01:10 PM
Auto Backup feature Kenny Gioia Tips & Tricks 4 05-02-2003 08:49 AM
