Mbox 2 mini not working after firmware update
Hello,I just brought a mbox 2 mini from someone 2 days ago and it was working but with alot of error messages. I attempted to upgrade the firmware but now it stopped working completely.I had the mbox 2 mini plugged into a usb hub during upgrade and I read after the mishap that the unit would become inoperable. Does this mean that the unit is no longer any good because I was updating thru a hub and not directly to a usb port ? If so I just wasted my money on another avid/digidesign interface that always has crazy issues.Is there a way to reset the interface or is it dead ? thanks in advance
Protools 8.03 installed on Imac G5 10.5.8 with mbox 2 mini interface Model Name: iMac Model Identifier: iMac7,1 Processor Name: Intel Core 2 Duo Processor Speed: 2 GHz Number Of Processors: 1 Total Number Of Cores: 2 L2 Cache: 4 MB Memory: 4 GB |
Re: Mbox 2 mini not working after firmware update
Since I spent the last 3 hours dealing with this issue, here's some potential help which I could not find anywhere else on the Avid forums.
Description of issue: After attempting to install a firmware update (1.38) on an Mbox 2 mini, the mbox itself is not able to connect. The LED will not turn on, nor will the connection occur in the system preferences. If you find yourself with an Mbox 2 (mini) that seems completely inoperable after a firmware update, try the following: 1. Delete the file named "DigidesignMbox2.kext" from the following location: Macintosh HD/System/Library/Extensions/ 2. Reboot 3. Reinstall Pro Tools (after uninstalling) 4. Reboot *this procedure should work for any mbox2 unit that has had the incorrect firmware update installed. |
Voidsloth - you rule.
The process outlined works for the normal mbox 2 as well. |
Firmware Update has made Mbox 2 stop working. | robloomis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-30-2011 09:13 AM |
MBox 2 Mini Firmware Update Crash | blueherdim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-25-2011 10:40 PM |
Mbox 2 Mini not responding after firmware update failure | creeperdet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-13-2011 01:13 PM |
Mbox 2 mini not working after firmware update | dizzove | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-23-2011 10:24 AM |
computer shutdown during firmware update on mbox 2 mini | agra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-16-2011 07:37 PM |
