Old 08-10-2009, 03:08 AM
summerbankstudios summerbankstudios is offline
Default how to connect s/pdif to analogue desk
i have a mac pro computer, 003 digi and focusrite octopre le and use a soundtracs analogue desk ,at the moment i have 16 ins and out with this setup ,i want to utilise the s/pdif connectons to get 18 ins outs but have never used spdif and have no idea how to connect any ideas?thanks
Old 08-10-2009, 06:57 AM
daeron80 daeron80 is offline
Default Re: how to connect s/pdif to analogue desk
Which mixer? Topaz 24? If it's an all-analog desk, then it doesn't have S/PDIF I/O. In that case, you'd need a stereo A/D and D/A that can use S/PDIF. Say you used a Panasonic SV-3700 DAT machine - a pair of RCA cables between 003 and DAT, four mic cables between DAT and mixer. Simple as that. S/PDIF, you know, is a digital format.
If your desk does have a pair of RCA-type coaxial connectors for S/PDIF I/O, then it's as simple as running RCA cables between the two. Your Soundtracs manual should explain how to select those digital inputs and outputs.
David J. Finnamore
Nyquist was right.
PT 2019.6 Ultimate | Omni | macOS Sierra
PT 2019.6 | Saffire Pro 40 | Win10
Can't connect Fantom X6 via S/PDIF to 003r entropylabs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-22-2010 07:42 PM
003 digital inputs will not connect, S/PDIF nor Optical explorationx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-08-2008 06:14 AM
Analogue Desk opinions from Old Skool BIG D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-11-2005 03:06 AM
how do I connect DBX386 S/PDIF to the 002R??? lastounce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-08-2005 06:37 PM
Analogue desk for about USD$20k Marc Edwards Tips & Tricks 9 06-26-2000 09:07 PM
