Old 09-25-2006, 11:22 AM
spicyrelish spicyrelish is offline
Default DAE error 9022 ? - Cannot open large project?
Two projects that I have just beat detected(using PT 7.2) will not open. After about 5-10 minutes of loading fade files, It reports: DAE error 9022. not sure what his means but there are not too many plugins or tracks used in the project, but there are a whole lot of fades and regions. Is this just a lack of computer memory and could it be fixed if I got more than the 2 gigs of memory for my G5 dual 2.0? ... or is there some other reason/solution that someone here in this forum might be able to explain to me?
Thanks!!
Kameron White
Old 09-25-2006, 11:39 AM
DigiTechSupt's Avatar
Default Re: DAE error 9022 ? - Cannot open large project?
Can you use Import Session Data to a new session and try importing tracks one by one to see if you can locate a particular track or tracks that are causing the problem? Have you tried trashing prefs or database files yet?
Avid Audio Tech Support
Support FAQ
Old 09-25-2006, 11:45 AM
have not tried to import track by track since I had assumed that it was an overall insufficient memory problem and not based on individual track corruption. It is happening the same on two totally different projects that I just recently beat detected, which also makes me believe that it's not file corruption.... what is error 9022 mean? what specific preferences would you recommend that I trash?
Thank you,
Kam
Old 09-25-2006, 12:03 PM
SessionKat SessionKat is offline
A -9022 error translates to "kFicTooManyItemsErr// Number of needed items goes beyond a lists max size."
You mentioned using Beat Detect on these sessions....its possible that some unused region/unused fade faile corruption is going on.
Maybe try removing all unused regions? Or consolidating some playlists, then removing unused regions?
-tv
Tim vdB
Avid Audio
"There's a fine line between stupid and clever."
Old 09-25-2006, 12:18 PM
there were not alot of audio files in the projects. . . just perhaps 10 stems plus the 12 tracks of live drums (10 takes - some real short). Also, both songs are ~4 minutes. so, I doubt there are any "unsed regions' at all at this point. I was just going to edit(comp) the live drums down into a master drums tracks, at which point I would consolidate and there would be plenty of unused audio/regions. but as for now, everything is necessary... I even need the stems to hear/know how to comp the drums. even if there were unused regions, I cannot open the project in order to delete them... i think that the problem is as the error 9022 reads: too many items in list. . meaning too many regions or fades. . . It seems that you can work/edit with a project and save it larger than protools can open. not sure if more cpu memory would make any difference here or if this is just a pt software limit, but I'm afraid that even if I were to import the tracks one by one, that may be sucessful, but saving and reopening again may not be successful.
Kam
Old 09-26-2006, 09:49 AM
Scott Goldberg Scott Goldberg is offline
A force shuffle of the DSP chips "might" help but that's a long shot. Also, take a look at your setup and see how many chips/voices you have allocated for the session. Maybe you have an insufficient amount of voices/chips allocated to this particular project?
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
Path error each time I open a project Sam C macOS 16 01-15-2013 05:18 AM
error 9022 garnoil Post - Surround - Video 2 01-20-2010 04:53 PM
error (-5000) when trying to open a project from another studio marcioguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-08-2008 11:54 AM
DAE Error -9022 stanonbass Pro Tools TDM Systems (Mac) 2 02-18-2007 05:16 PM
large 96k project can't open Byfar Prod Pro Tools TDM Systems (Mac) 2 09-10-2002 12:05 AM
