Old 05-02-2005, 11:00 PM
dubman dubman is offline
Default midi and tempo changing
D ose anyone know if you can change the tempo of a track without changing the tempo of a midi track. I'v got a midi loop that I want to match the tempo to.I can do it well enuogh with audio loops but the midi track seems to change no matter what I do.
Old 05-02-2005, 11:35 PM
BIG D BIG D is offline
Default Re: midi and tempo changing
Only way (if I understand you)is to record the MIDI loop as Audio, say 2 or 4 bars. Once in audio use the time compression/expansion tool to adjust, Or alternatively, find out what tempo you want the loop to be and record it independently at that tempo.
I'm a bit confused as if it's a MIDI loop you should be able to make it any tempo you want.
Maybe let us know exactly what the 2 elements are that you are trying to lock.
Hope that helps.
Best,
Big D
INTEL QUAD XEON
INTEL S5000XVN serverboard
4 gig Fully Buffered Ram (About to add more)
3 x WD500gig SATA, 1 x WD1T32mb SATA cache Green
NVIDIA Geforce 7300le,
Command 8,HD2,192,Massive Pack 4
Windows 7 64 bit PTHD 9
Old 05-03-2005, 04:43 AM
jondun jondun is offline
Default Re: midi and tempo changing - dj mixes
Hi
i am a new user of protools LE and am hoping for some basic guidance on mixing 2 precorded audiotracks together (as in dj / club mixing of records ), I am aware of the pitch-shift function, but this is a 'relative' operation i.e. it can increase bpm by a prescribed percentage. If i have 2 precorded audio tracks, i presume i need to identify their respective bpm first, then manipulate one to match the other.
asny assistance with this would be very helpful
Thanks
jonD
Old 05-03-2005, 03:57 PM
Yeah I'v got a loop of midi goin, (not audio) and I want to set the song tempo to that of the loop. I can do it easy enough in cubaseSX but I'd like to do it in PT's LE.
Need to Change tempo but without changing existing midi data tempo? Einsteinwannabe Pro Tools M-Powered (Mac) 2 09-18-2010 06:58 AM
Changing MIDI Tempo ? polaredit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-14-2007 03:52 PM
Changing tempo w/out changing midi performance??? toddm7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-12-2005 10:35 AM
Changing Midi tempo poppy Pro Tools TDM Systems (Mac) 4 06-20-2005 11:23 PM
changing tempo without changing midi wizdoom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-20-2004 05:40 AM
