Factory presets are gone
Hi! Somehow all my factory presets of the plug-ins are gone, and this is very bad! I use my Virus a lot, but I can't find the sounds!! Anybody????????
Re: Factory presets are gone
trash your prefs, empty, and restart. that should do the trick.
It happens occasionally to me as well |
Sometimes if you import a preset (if you know where they are) from the library it will then find it all.
Good luck
Pro Tools Tutorials: Mixing Heavy Rock & Metal • Pro Tools 11 - Tips and Tricks • Delay Explained • Tracking Rock - Drums • Mixing Rock • Music Production with Pro Tools • Pro Tools Tips and Tricks Vol. 2 • Pro Tools Tips and Tricks Vol. 3 • Elastic Audio in Action |
Or you could always go to the plug-in librarian menu (the little arrow beside where you choose a preset) and choose Plug-in preferences > Set Root Settings Folder, then navigate to the OSX Boot Volume > Library > Application Support > Digidesign, then choose the Plug-in Settings Folder and click "Choose". Perhaps you brought in a session from another system and that preference got fouled. It use to happen to me all the time back in the 5.1 days, but I haven't seen it in PT 6 yet. If you're still using 5.x, the same procedure above would apply, except you'll find the plug-ins settings folder in Mac HD > System folder > DAE folder. Good luck!!
By the way, Dave Schober's suggestion above would probably clear up this issue too since that would cause it to retarget the folder anyway. |
EXPAND 2 - Where are my factory presets? | musiclee | Pro Tools 11 | 2 | 12-05-2013 08:03 AM |
Factory presets for Pitchblender?? | lydpik | Tips & Tricks | 1 | 06-11-2004 09:56 AM |
Factory presets for Pitchblender?? | lydpik | Pro Tools TDM Systems (Mac) | 3 | 06-11-2004 08:17 AM |
Factory Presets | Wolfgang Eller | Pro Tools TDM Systems (Mac) | 4 | 07-08-2001 01:26 AM |
Factory presets are GONE! | marcelloz | Pro Tools TDM Systems (Mac) | 5 | 05-02-2001 07:53 PM |
