Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 11-25-2018, 10:43 AM
Tom Case Tom Case is offline
Default Saving re linked audio?
Hi, I opened a session and the drum tracks were greyed out, with the missing audio dialoge. I closed the session, plugged in my back up drive, and the session opened up correctly.
So, how do I import the audio from the back up session folder, back into the main session folder on my main audio drive? I did make a copy session with the audio copied, but I would also like to have those tracks back where I want them.
Thanks everyone
Tom
Old 11-25-2018, 11:38 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Saving re linked audio?
You can use either the Import Audio option which will import clips only, or the Import Session Data option which can import tracks with options of what info to import from the original tracks. Check the reference manual for details though it's pretty self-explanatory.
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2020.5
Old 11-25-2018, 12:32 PM
Top Jimmy's Avatar
I like to use the save copy function making sure to have it copy all audio. This brings everything together in a new folder.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.4.
Pro Tools HD Native 2020.3, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 11-25-2018, 01:15 PM
BScout BScout is offline
Go to workspace.
Open up in the left-side the pro tools session and audio folder. Select audio folder.
On right side, sort audio files by file path.
Select all the ones that are in the wrong file path (on your backup drive)
Right-click and select "Copy and Relink"
That'll copy all those files to your main audio folder and relink them in your session.
Then just save session.
Pro Tools Ult 2019.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 11-25-2018, 02:26 PM
Great advice above. Here's one thing to check, and one more thing to add to your workflow; Open Preferences and make sure that you check the box for Always Copy On Import(or something like that). And, to really cover your ASSets, copy the files(outside of PT) directly into the session folder and import from there
Keeping markers linked to audio as you shuffle? DC-Choppah Tips & Tricks 6 10-22-2019 05:09 PM
Horrible Heal bug in 11.2 HD (noticed with linked AAFs and MXF audio) Pete Gates Pro Tools 11 35 11-14-2016 02:14 AM
Markers linked to audio doesthisexist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-29-2009 03:15 PM
Files linked, not linked, linked, not linked.... Rader Ranch Pro Tools TDM Systems (Mac) 3 08-20-2008 07:18 AM
