Old 09-28-2009, 10:00 AM
doesthisexist doesthisexist is offline
Default Markers linked to audio
Hi I'm wanting to have markers linked to specific places in an audio track - spoken voice - I want to insert silences at many places within the track but still have the markers corresponding to specific spoken words - I'm not seeing how to do this!!
I've read the chapter on markers over and over again but I must be missing something - no matter what I try the markers stay at the same place on the timeline and don't move with the audio.
Help please, Colin
I'm using 7.3
Windows 10 Home - 64bit - 8Gb Ram
Intel Core i3-4130 3.40 GHz
Mbox Mini with Pro Tools Express 10.3.4
Old 09-28-2009, 10:04 AM
AndyJCP AndyJCP is offline
Default Re: Markers linked to audio
+1
Old 09-28-2009, 03:43 PM
The Weed's Avatar
The Weed The Weed is offline
Lets say you have Pro Tools in Shuffle mode and you want to delete a selected section of audio, have everything to the right move up and also have the Markers move up. You have to make the same selection in the Markers Track as in the Audio Track.
Try this:
Place a Marker at the beginning of the section you want to delete - Marker 1 - and a Marker at the end of the section you want to delete - Marker 2. For this purpose, move the track containing the audio you want to delete to the top, right under the Marker Track. Now, click in the Marker Track to the left of Marker 1 so your cursor is blinking in the Marker Track. Tab to Marker 1. Shift Tab to Highlight the space between Marker 1 and Marker 2. Now Hold Down Shift and hit the Semi-Colon Key ";". You should now have the space between Marker 1 and Marker 2 highlighted in the Marker track and in the audio track. Make sure Shuffle is selected and hit Delete. Marker 1 will be deleted as will the space between Marker 1 and Marker 2 and the highlighted audio. Everything to the right on the audio track will move up and Marker 2 will move to Marker 1's position.
Repeat as necessary.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 09-29-2009, 03:15 PM
Hi Bruce,
Thanks for that - I'm wanting to insert silence between sentences - using your suggestions I've found out that by having another empty track open - making a selection then shift clicking in the Marker Track - Copy and Paste in Shuffle mode at the appropriate place in the Audio track - that does the trick.
Using Insert Silence from the Edit Menu doesn't work.
Anyway I'm now able to do what I need to do and that's the main thing
Thanks again, Colin
Keeping markers linked to audio as you shuffle? DC-Choppah Tips & Tricks 6 10-22-2019 05:09 PM
Beat Markers Appearing As Elastic Audio Markers Fabdickson Pro Tools 9 1 03-06-2012 05:03 PM
Markers broken and throw errors [pics linked] koo_koo_bonkers Windows 4 11-30-2011 12:23 PM
Files linked, not linked, linked, not linked.... Rader Ranch Pro Tools TDM Systems (Mac) 3 08-20-2008 07:18 AM
moving audio & markers mixerboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-15-2003 12:16 AM
