Is the Focusrite Saffire Pro 24 compatible with PT11
I want to get PT 11 in the future. Currently I have a AT4033 mic and a M-Audio DMP3 stand alone pre-amp. Since the pre-amp is stand alone I need a interface. I am wanting to get the Focusrite Saffire Pro 24, will it be compatible with PT11? Also what's a good firewire sound card to purchase?
Thanks in advance |
Re: Is the Focusrite Saffire Pro 24 compatible with PT11
Yes it is. I use a combo of lS56 and saffire pro 40
I picked up a saffire pro 24 DSP a while back and it works great with pt11. Got it as a small portable unit, and I liked the idea of the VRM. Still haven't used VRM enough to really get used to it, but seems to be useable.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
Best thing about the DSP is the reverb on board also.....(and VRM)
Waiting for Focusrite to drop a box like MOTU - ie more DSP choices -
Hi CG Kid,
If you are on a PC check out this article for firewire compatibility. http://d3se566zfvnmhf.cloudfront.net...tibility_0.pdf |
Focusrite Saffire PRO 14 | garymmadison | macOS | 4 | 08-10-2011 09:01 PM |
PT 9 + Focusrite Saffire Pro 40 ???? | alyule | Pro Tools 9 | 3 | 04-26-2011 11:20 AM |
Anyone using a Focusrite Saffire Pro 26 I/O ? | Ru_C | macOS | 1 | 03-17-2011 09:51 PM |
Focusrite Saffire 56 with PT9 | Meads | Pro Tools 9 | 126 | 02-01-2011 07:34 AM |
is digi 001 compatible with Focusrite Liquid Saffire pro 56? | piteco22 | General Discussion | 7 | 02-22-2010 07:24 PM |
