Using S/PDIF Output with Focusrite Scarlett 8i6
I need some help getting the S/PDIF out to work in my set up.
I've connect S/PDIF cables from the S/PDIF out of the 8i6 to the S/PDIF IN on the left JBL LSR4326 and then connect a S/PDIF from the left monitor S/PDIF OUT to the right monitor S/PDIF IN. I then switched the JBL's to S/PDIF mode using the software. Then, I selected S/PDIF Stereo out for an audio track I was testing with. Hit play..and nothing. No sound at all. Clearly there's some other step I'm missing but I can't figure out what. The PT Reference guide only talks about S/PDIF with respect to HD systems. I have the I/O for the 8i6 set up properly...all the available INS and OUTS are showing, including the S/PDIF. If I go back to selecting the usual MAIN outs for the 8i6, switch the JBL's back to Analog and play...its fine. I also have a S/PDIF connecting audio out from my Motif XS8 to S/PDIF in on the 8i6, and that plays fine. I can record anything I play on the Motif using the S/PDIF out of the Motif to the IN on the Scarlett and setting up an audio track to read that input. So I know S/PDIF is working...at least on input side. Not sure what I'm missing here. Can someone shed some light? Thanks
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Re: Using S/PDIF Output with Focusrite Scarlett 8i6
Never mind, I got it sorted. Just wasn't something obvious, but once I got and see it, it makes a bit of sense...sort of.
Focusrite Scarlett 18i8 | kyluigi | Third Party Interfaces | 6 | 10-17-2013 08:14 AM |
Focusrite Saffire/Scarlett & PT9 Question... | acmost | Third Party Interfaces | 5 | 07-06-2013 11:37 AM |
Focusrite Scarlett 8i6 - no inputs detected? | mooquu | Third Party Interfaces | 5 | 12-17-2012 09:03 AM |
Focusrite Scarlett - A Steal! | RussUK | General Discussion | 45 | 05-12-2010 03:29 PM |
Focusrite Scarlett | justus1900 | Virtual Instruments | 1 | 12-18-2009 08:43 PM |
