Digi 192 expansion question
Ok I currently have a 192 with 2 analog input cards equaling 16 analog inputs, 1 analog output card for 8 outs, and a digital card that I never use! Can I pull out the digital i/o card and put in another analog output card giving me 16inX16out analog? Or will I need another 192 to acheave 8 more analog outs?
Re: Digi 192 expansion question
You need another chassis, or go to a HD IO (which can do 16x16 analog, and cards are not compatible), or use the ADAT Out on your digital card. |
I was wanting 8 more outs for analog summing! Guess I'll find another 192... That'll give me the 8 more outs plus 8 more ins! Thanks man
For around $200, you could connect a Behringer ADA8002(the red version) with 2 lightpipes and gain 8 more inputs AND outputs via the digital ports on the 192
No, AVID/Digi interfaces are 16 I/O max. ADAT is also limited to 48k (no SMUX).
A second 192 is a good way to go. |
Connecting lightpipe out to the Behringer would get the OP 8 more analog outputs. If that's all he really needs, its much cheaper than a second 192(but I do agree another 192 will bring other advantages)
The other consideration for analog summing is that he'll experience comb filtering by mixing converters.
Or just give up, save time, money and hassle and mix in the box....
Yep. Engage HEAT and stay ITB. Works well and less hassle. I have an LFC that usually only actually runs as a monitor controller. Been a while since an album was actually mixed on it.
Digi 002 expansion question | delta | macOS | 4 | 02-16-2015 09:59 AM |
7.4 with Digi Expansion HD | bobo mark | Pro Tools TDM Systems (Mac) | 4 | 08-22-2008 08:53 PM |
Another optical expansion question question for boffins | Che_Guitarra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-23-2008 11:21 PM |
Expansion for C8 >Digi>? | dio | ProControl, Control|24, Command|8 | 2 | 09-21-2005 11:50 PM |
192 IO Digi expansion card | Roger Stauss | Pro Tools TDM Systems (Mac) | 1 | 03-09-2005 06:27 PM |
