Old 04-09-2004, 03:10 PM
Bus 7-8 Bus 7-8 is offline
Default Only getting output from the left speaker
This is not strictly a Pro Tools problem but this site has such great audio buffs that it's worth a try. Since I installed a DVD player I've discovered that I'm only getting output from the left speaker. I've checked all the panning/balance and volume levels on all my audio programs (including the DVD software) but they don't appear to be the problem. I've also opened up the computer and checked for dodgy connections. When I plug into my M box (the headphone output) and lauch a PT session both speakers are fine. It seems that it only happens when I plug into the computer's line-in (I have two and I've checked both)
Old 04-09-2004, 04:12 PM
graveleye's Avatar
graveleye graveleye is offline
Default Re: Only getting output from the left speaker
Hi Bus,
Not sure how you have your dvd player plugged in, but with mine you have a really small plug wire that goes from your dvd/cd drive and plugs to your mother board. On many mobos the jack is only two posts stick up from the board itself. Check to make sure you plugged that in correctly. I could be pretty easy to plug it in firm, but only one of the male posts on the board is actually covered. Does this make sense? Good luck,
Kev
GIGABYTE X58A-UD3R, INTEL CORE i7 960, NVIDIA GEFORCE 8400GS, WIN 7, MOTU 896mk3 HYBRID, PT 10.3.2
Old 04-09-2004, 07:00 PM
Wow, cheers Kev(!) I just replugged it and it is working fine. That is very much appreciated. Another problem I had has been solved in this forum
Sound only coming out of left speaker chrisshack89 Windows 5 05-29-2013 12:35 AM
Only left speaker works benzclk1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 07-02-2009 01:48 PM
c/24 no sound in left speaker out raga2000 ProControl, Control|24, Command|8 2 06-04-2007 02:11 PM
Left Speaker Only tsewards 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 12-04-2006 06:24 PM
Buzzing in left monitor speaker neil_mcdermott ICON & C|24 5 08-10-2002 02:16 PM
