Old 02-15-2017, 06:59 PM
ejinbc ejinbc is offline
Default Inexpensive controller option - Command|8 & iPad2
I just wanted to highlight a very inexpensive path to (almost) controller Nirvana.
Couple a Command|8 (350$ CDN on CL) and an iPAD2 (200$ CND on CL) with Pro Tools Control for a relatively inexpensive way to get 16 faders ( 2 x 8 independent blocks) and access to all the buttons that are missing on the Command|8 (e.g. automation) by using the Eucon support in Pro Tools Control on the iPad.
Obvious to many I am sure, but just in case...
Old 02-16-2017, 09:34 AM
Carl Kolchak Carl Kolchak is offline
Default Re: Inexpensive controller option - Command|8 & iPad2
Does that actually work?
I thought Eucon wouldn't work with other control surfaces, or is that only a conflict with Ethernet (Command | 8 being setup under MIDI controllers, so may not be a problem)?
Old 02-16-2017, 10:53 PM
So far it works great.
The Command|8 is USB and a midi controller, the iPad Control is Eucon and shows up under Ethernet controllers. Both controllers work and are fully independent. Pairing the two makes a very effective poor man's DAW controller. My DAW stays offline so I set up a local wifi network with my PC.
Configuration: 3770K PC O/C 4.5Ghz, Asus P8Z77 MB, 512 G SSD, 16 G Ram, Motu 1248 + Motu 8Pre, Win10 Pro, Pro Tools 12.7, Waves Gold, Kontakt Komplete 10.
Old 02-16-2017, 11:24 PM
Sounds great :)
Old 02-17-2017, 10:03 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Same with the HUI based setups.
I keep a wired iPad up and stopped using an older 8 fader Mackie/Emagic unit.
(Noisy)
Works well.
(Help us Help You)<<<click here
PT's HD12.8 MacOS 10.12.5
OS 10.9.5 (Dual PT HD10.3.10 & HD12.7.1)
(MP 5,1 / 64-Gb)
MOTU FW-CoreAudio
Stereo, 5.1.2 and music design creation.
Post Music-Sound, Production enhancements.
Old 02-17-2017, 12:14 PM
Cool, I will check that out - I have a Command | 8.
I'm certain there was a conflict with Eucon, but it must have been with Icon/D-Command???
Inexpensive Midi Controller Anyone? LightWing Pro Tools 12 Discussion 4 01-27-2016 04:44 AM
D-Command/ X-MON sum option antonis ICON & C|24 9 11-03-2015 10:01 PM
can i run Pro Tools 9 on a iPad2? Mike Hunt Pro Tools 9 Discussion 9 06-08-2013 08:28 PM
Command+option+FWD slash in PT LE Ratboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-08-2005 04:36 PM
What is your favorite inexpensive Keyboard Controller? jamieorc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-09-2002 03:18 PM
