Old 02-10-2017, 02:54 PM
stefanboman stefanboman is offline
Default Re: S6 graphic eq curves compatible plugins
Thanks!
Guess I'm behind on updating my McDsp. . Sorry!
Thanks for the quick response! Excellent to see Avid being so active here :)
On a side note. Please prioritize custom mapping of plugin parameters!
That would be a fantastic upgrade and we the users could solve the sometimes faulty parameter mapping.
Great for the users and relief for the developers. Win win.
Have a great weekend!
Old 02-10-2017, 05:28 PM
rus5 rus5 is offline
Originally Posted by creativecontrol View Post
Sonnox, McDSP, Fabfilter definitely have plug-ins that work with the curves.
Jeff
Just a quick note on the FabFilter compressor plug (Pro C-2) - FF says it is supposed to support the S6 plot functions but it doesn't on my PT12.7.0, S6 M40 V3.5 system. I've contacted them and they say they're looking into it. My guess is there's an update discrepancy and they'll catch it and fix it. But as of now, no plots (though the plug works fine, maps to the controls and works great). Their EQ plug (Pro Q-2) plots do show up properly. It maps to the controls in a somewhat confusing way but I would have expected that because of the way the plug itself works (and they're open to any suggestions on how to improve it).
Old 02-11-2017, 05:07 AM
txm txm is offline
Fab Filter is amazing.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old 02-12-2017, 03:26 AM
Branko's Avatar
Branko Branko is offline
You have my vote for this cause! A must.
Branko Neskov c.a.s.
www.loudness-films.pt
Old 02-17-2017, 04:03 AM
innenhofstudios innenhofstudios is offline
Waves (Q, REN and SSL) would be great.
But another thing i would like to see : wipe through the Bands would be helpful, or do i just dont know how ???
Jumping to Low/High Cut on the MainModule Screen...
www.innenhofstudios.at
Old 02-17-2017, 08:12 AM
creativecontrol's Avatar
Greetings,
I just verified on my rig that all the Waves plug-ins that you mentioned look just fine in dedicated EQ mode (magenta) on the S6. If you access them in Inserts mode (teal) they may not be exactly what you would expect. I will work with Waves to get the Insert tables tweaked but in the meantime the primary EQ looks and works great. Make sure you have current versions of Waves plug-ins as I know they have done some pagetable work over the last 6 months.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-17-2017, 08:48 AM
Use SHIFT plus buttons on lower right bottom of MTM to page to HP LP.
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-23-2017, 09:55 AM
Greetings,
Jeff
You are right. I dont have latest versions but H-EQ has.
They work on the knob module and on the MTM Knobs. But no Curve :/
Old 03-01-2017, 05:51 AM
They are working on it and should have an update released shortly.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-01-2017, 05:57 PM
rcutz rcutz is offline
Jeff
Jeff, did you have the opportunity to talk with the DMG guy? Equality is maped correctly as eq insert (magenta) but did no display the graphic curve.
best.
Ricardo Cutz
Re-recording mixer/sound editor supervisor.
Http://106db.com.br
Are some 64 bit plugins 32 bit compatible? John McDaniel AAX Plug-ins 3 01-28-2014 12:10 PM
Non compatible plugins. Why not? Armando Pro Tools TDM Systems (Mac) 3 03-18-2005 03:25 PM
film eq curves, dvd eq curves ashish Post - Surround - Video 3 02-02-2004 05:17 AM
002 compatible plugins Walling1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-14-2002 07:22 PM
compatible plugins PaulG 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-14-2000 07:17 AM
