Old 02-08-2003, 02:10 PM
jpd jpd is offline
Default Mbox And mic pre amps
I am a new user and and wondering if there is any significant benefit to using a low cost mic pre amp (100$-300$) over simply using the pres built into the MBox. Also any tips on good swiss army type mics that work well with percussion acustic guitar and voice
Old 02-08-2003, 04:30 PM
lynxxx lynxxx is offline
Default Re: Mbox And mic pre amps
1.The only way to answer that is to try it on the application you need it for(before buying-if possible). Entirely subjective.
2.Shure SM 57 or SM 58. THE Swiss army knife of microphones (for a dynamic, anyway). Ultimately, you'll want lots, condensers, etc.
Mbox /PTLE 5.2
G4 QS Dual 1Ghz OS 9.2.2
512mb RAM
80 G Seagate internal HD
60 G IBM Deskstar internal HD
40 G Buslink (Seagate)FW ext.HD
Old 02-09-2003, 03:06 AM
Larryboy Larryboy is offline
Don`t replace something that only goes to second base with something that only goes to first. If you`re looking for more outboard gear to use with the Mbox then a compressor (for use with the inserts) would be a better buy which can dramatically change the sound.
27in 3gHz Intel iMac w/8gb RAM, 13" MacBook Pro 2.7gHz i7, Pro Tools 10, Logic Pro 9, Apogee Quartet, Grace M101, Rosetta 800, Speck X-Sum, Roland XV-5050, Event PS6
Old 02-09-2003, 07:11 PM
glamfolk glamfolk is offline
i use one of the cheap tube mic pre's (ART) and it warms up my 58 very nicely.
Old 02-10-2003, 09:19 AM
Duardo Duardo is offline
The Focusrite preamps in the M Box are actually pretty decent preamps. I don't think you'd necessarily find anything "better" for the price, although you may find somethign "different" that's just as good. Some of the cheaper tube preamps especially certainly do offer a different color than the (relatively) transparent preamps in the M Box, although they may not spec out as well nor be a better choice for every situation.
-Duardo
Mbox 3 Pre amps vs. External Pre amps? evanbgrove 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-10-2011 06:21 AM
Mbox 2 pro... Pre Amps (vs) 003 Pre... Amps Norm Mix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-24-2009 03:37 AM
mBox pre amps Kia43 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 03-03-2006 04:43 PM
do you use pre amps with your mbox ? hodge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-28-2005 11:48 AM
The Pre-amps on MBox is amazing J. Guerrero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-10-2002 01:48 AM
