I apologize for the stupid question, How do i go about saving preset info for plug ins and eq setting in PT???
ex.. using tl space and the generic digi eq for guitars, after I set it and use it for a recording how do I save it to use later if you could point me to where the info is in manual I would appreciate it sorry for the "newbie" question
mac pro, 2.66ghz 4gigs ram, 1 internal 250 and 1 internal 500 hard drive, digi 003 board, PT 7.3 www.James Angelucci.com |
In PT8 (probably very similar, if not the same in PT7.3) at the top of your plugin window, it says "preset" with an arrow slightly to the right of it. When you click the arrow it says "save setting", "save settings as", "copy settings", "import settings" etc. If you want to locate them later, there are in this location : HD>Library>Application Support>Digidesign>Plugin Settings. Hope this helps.
and Shift S isn't it?
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
So when i want to "recall" the preset and use it in another project I go to that "directory"??
thanks a Lot!!!!
When you open up an instance of the plugin you want to use, it should be listed in the same list with the preset settings that come with the plugin.
Plugin Preset Save - Can't locate settings folder | SamboBing | Pro Tools 11 | 4 | 06-23-2013 05:01 PM |
TL Space Preset not loading | lukeyy | macOS | 3 | 06-11-2012 11:32 AM |
Plug-in user preset save | adaboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-10-2010 09:41 PM |
TL Space Preset CRASHING the system - help ? | danocaster | Pro Tools TDM Systems (Mac) | 3 | 01-09-2009 02:57 PM |
TL Space Native-Preset Not Loading | RokVox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-25-2007 03:44 PM |
