Old 03-08-2013, 09:21 PM
Focuret Focuret is offline
Exclamation Updated Eucontrol to 2.7 and upgraded to Mountain Lion 10.8.2. Eucon now broken.
I replaced my MacBook Pro's internal HDD with an SSD and migrated apps to it. The OS was also upgraded and so was Eucontrol. But now when I try to launch Eucontrol it crashes.
The error report says this:
Process: EuControl [582]
Path: /Applications/Euphonix/EuControl.app/Contents/MacOS/EuControl
Identifier: com.Euphonix.EuControl
Version: 2.7.0 (87367)
Code Type: X86 (Native)
Parent Process: launchd [257]
User ID: 504
Date/Time: 2013-03-09 13:15:12.252 +0800
OS Version: Mac OS X 10.8.2 (12C60)
Report Version: 10
Interval Since Last Report: 2946 sec
Crashes Since Last Report: 10
Per-App Crashes Since Last Report: -5
Anonymous UUID: A7D5EAF3-049C-21FC-01D9-75122072BB84
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: /usr/local/lib/libEuCon2.dylib
Referenced from: /Applications/Euphonix/EuControl.app/Contents/MacOS/EuControl
Reason: no suitable image found. Did find:
/usr/local/lib/libEuCon2.dylib: stat() failed with errno=13
Binary Images:
0x1000 - 0x437fff +com.Euphonix.EuControl (2.7.0 - 87367) <05E39FBA-795E-A5BF-2EF4-9AD09A6C88B9> /Applications/Euphonix/EuControl.app/Contents/MacOS/EuControl
0x7f6000 - 0x8beffa org.python.python (2.5.6 - 2.5) <1F100B5F-891C-3FF8-9183-C1443861D594> /System/Library/Frameworks/Python.framework/Versions/2.5/Python
0x8feac000 - 0x8fedee57 dyld (210.2.3) <23DBDBB1-1D21-342C-AC2A-0E55F27E6A1F> /usr/lib/dyld
Model: MacBookPro8,2, BootROM MBP81.0047.B27, 4 processors, Intel Core i7, 2.2 GHz, 16 GB, SMC 1.69f4
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 512 MB
Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1333 MHz, 0x04CD, 0x46412D3133333343392D3847535100000020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1333 MHz, 0x04CD, 0x46412D3133333343392D3847535100000020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.98.81.22)
Bluetooth: Version 4.0.9f33 10885, 2 service, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: Samsung SSD 840 Series, 120.03 GB
Serial ATA Device: WDC WD10JPVT-35A1YT0, 1 TB
USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0xfa200000 / 3
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfa100000 / 2
USB Device: BRCM2070 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 5
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821a, 0xfa113000 / 7
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0252, 0xfa120000 / 4
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfd100000 / 2
USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfd120000 / 4
USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd123000 / 6
USB Device: iLok, 0x088e, 0x5036, 0xfd123100 / 8
USB Device: Apple Keyboard, apple_vendor_id, 0x024f, 0xfd123200 / 7
USB Device: Samsung SMD220SU, 0x17e9 (DisplayLink (UK) Ltd.), 0x0100, 0xfd122000 / 5
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd110000 / 3
FireWire Device: Mbox Pro, Avid, 400mbit_speed
I'm supposed to be recording a session right now but after going through a whole bunch of BS transferring files I finally get everything ready then Eucontrol doesn't work.
Any ideas guys?
MacBook Pro Touch Bar (15-inch, 2016 2016), 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3, Radeon Pro 460 4096 MB
Intel HD Graphics 530 1536 MB | macOS Monterey | Avid HD Native Thunderbolt | Avid HD Omni | Pro Tools Ultimate | Avid Artist Control | Avid Artist Mix
Avid Artist Transport | Genelec 8351b Monitors | Genelec 7360A Subwoofer x2 | Slate Digital VMS Virtual Microphone
EUCON/EuControl 3.1 available Artist PM Artist Series 43 05-13-2015 02:15 AM
EUCON/EuControl 3.1 Now Available Artist PM Technical Alerts 0 12-13-2013 06:11 PM
Impossible to start Pro Tools on MacPro after downgrade Mountain Lion back to LION DESVED Pro Tools HDX & HD Native Systems (Mac) 2 05-21-2013 03:18 PM
Artist Controllers and EuCon with Mountain Lion 10.8? Krzysztof Artist Series 43 12-03-2012 01:21 PM
