  #21
Old 04-23-2013, 04:19 AM
Weg Weg is offline
Default Re: VE Pro 5 and Pro Tools 11
Maybe I misunderstand.
When I use VEP with, say, kontakt I set up one instrument track with the server plugin which counts as channel 1 for kontakts midi and audio.
Then I make another instrument track with no plugin, route the midi to the VEP kontakt channel 2 and have that audio piped back into the second instrument track.
I only mention since I used to use the midi+aux workflow until I realized that using only instrument tracks could achieve the same thing with less clutter.
ProTools 10.3.2
Mac Pro 8 core
10 gig ram
OSX 10.8
RME UFX
Artist Mix
  #22
Old 04-23-2013, 01:09 PM
spenner spenner is offline
For PT Strawberry the Instrument Track limit is 64 (facepalm). So, depending on the template, the MIDI+Aux method is still very useful.
However, the routing for this with VEP 5 on large templates can be the script for Les Misérables, which is another reason why I could use Strawberry 11.
  #23
Old 04-23-2013, 02:17 PM
YYR123's Avatar
YYR123 YYR123 is offline
I like it - strawberry
Daniel
  #24
Old 04-23-2013, 03:25 PM
Meet the edible version of PT native. Interesting how the Instrument Track limit and calories are about the same.
  #25
Old 04-24-2016, 01:53 PM
iyaron iyaron is offline
Originally Posted by krazylain View Post
An additional benefit of VEP5 is time. In Protools 10 you can use multiple instances of either 64bit or 32bit versions of VEP5 AAX or VEP5 RTAS.
If you don't care to upgrade all of your older 32bit VIs right now, you can continue to you those in Protools 11 via VE Pro 5.
You can also use other 64bit VIs that are not yet AAX via VEP5.
For e.g. your IK Multimedia VIs are not yet 64bit (Sampletank, Miroslav etc), but you can use them in ProTools 11 or other 64bit DAWs via VE Pro.
It's your call, but I'm sure IK and other VIs will all be 64bit soon. Maybe you can wait for AAX versions of those plugins and ignore VEP5.
One reason I like VEP is that you can sequence in any DAW without having to reload VIs. It is like using a very powerful and flexible external sound module.
Everyday Is A Good Day
http://www.bandmix.com/itzhak/ My Music
www.itzhakyaron.com
  #26
Old 04-24-2016, 01:58 PM
Hi
I keep hearing the term VI
I do not know what it means?
Also Multi Timbral ?
Can someone explain routing VEPro 5 on a dedicated server into Pro Tolls 11 native ?
I am having issues routing AIR expansion pack hosted on a dedicated PC with VEPro server int oPro tools 11
thanks
www.itzhakyaron.com
