Old 01-10-2019, 03:50 PM
bonzerboy bonzerboy is offline
Default Plugin Alliance Question Bx master deck
Do you use a limiter after the bx-Master deck or is it limiter. I understand it is for mastering but it is the final plugin except may a dither or are you suppose to use it as a compressor and then use a limiter
Wow am I groovy or what
Old 01-11-2019, 12:39 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Plugin Alliance Question Bx master deck
It’s an all in one with final limiting stage
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-11-2019, 03:39 AM
PatriotsBiker PatriotsBiker is offline
It's not a brick wall, though, right? IIRC, one can still hit the ceiling if not careful. Then again, I can't say that I've heard it clip.
Old 01-11-2019, 05:00 AM
Thanks for the reply , One more thing ,, Looks like Plug in Alliance released a new plug in called spl IRON. Wasnt sure iftha was similar to the Master deck. In one of the video a guy has a waves L 1 plug in after the Iron plug in
Old 01-11-2019, 06:14 AM
I think these are two different things. The desk has a compressor working behind the scenes as part of it's processing. The Iron is a compressor. (might be more, but I have not looked at it much at all.)
Old 01-11-2019, 11:35 AM
onbeat's Avatar
onbeat onbeat is offline
I do use Pro L2 after it but just for dither.
Mac Studio M1 Max
Apollo X6
MacOS Ventura
Old 01-11-2019, 12:29 PM
even thou you use it for dither would that also brick wall at where the plug in would be set?
Old 01-11-2019, 09:21 PM
onbeat's Avatar
Yes, pretty much, there isn't any limiting as far as pro l2 goes. That I've noticed anyway.
Mac Studio M1 Max
Apollo X6
MacOS Ventura
HTML code is On
Question For Those Having Plugin Alliance Issues PatriotsBiker Pro Tools 12 11 11-09-2017 05:15 PM
Free Distortion Plugin Available from Plugin Alliance Seafoam_Green AAX Plug-ins 14 08-09-2016 09:41 PM
Anyone else have issues with Plugin Alliance Rtas plugin presets? realizment Windows 0 04-01-2015 05:04 AM
Mega plugin deals!! Slate, plugin alliance etc crizdee AAX Plug-ins 3 02-06-2014 11:03 AM
Master Fader and First Plugin Question... M2E Pro Tools TDM Systems (Mac) 5 01-01-2011 02:32 PM
