Old 12-07-2018, 05:56 AM
PatriotsBiker PatriotsBiker is offline
Default Transparent De-essers
See question at bottom related to this description.
I've recently purchased the UAD Manley VOX Box, which includes a de-esser element. It's transparency is nothing like I've used before. I used it for my awful vocals and it took out the bad, harsh edge I had in the 3k area, but did not simply notch it out like others have. Using it on a resonant guitar in a small room was love at first strum. My acoustics' tracking now results in pleasing warm sounds.
I guess by "transparent", I mean to say that it leaves the bulk of your sound in-tact. In other words, definitely NOT a notch filter.
So the question: Good, transparent de-essers. Do you have a nice, transparent de-esser that you can advise?
Thanks in advance
Old 12-07-2018, 06:13 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Default Re: Transparent De-essers
I've got a bunch but I like the original Waves one much of the time.
https://www.waves.com/plugins/deesser
Never liked the Renaissance DeEsser by comparison. Always found it a bit 'spitty' and grainy in the top end.
We worth giving the Avid Dyn3 De-Esser a go too!
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 12-07-2018, 06:32 AM
AlexLakis AlexLakis is offline
I owned a Voxbox for some time, I think I liked the owner's manual better than the actual gear! Definitely a recommended read even if you don't own the unit itself.
I do a lot of de-essing thru automation, but if I'm just slapping a plugin on I use either Eiosis' e2Deesser or Massey's De:Esser. I've found the key for good results to my ears for both plugins is to use the mix knob.
Old 12-07-2018, 06:50 AM
reidj reidj is offline
Izotope RX and the Spectral Repair module is my go to go difficult esses. Ultra clean and precise. If I'm in a rush the Fab Filter Pro DS is what I would put on a track to tame sibilant voals or dialog in my case.
Old 12-07-2018, 07:02 AM
WorldStudios WorldStudios is offline
I have many, but Sonnox Supressor is king of the transparacy hill. This I think, partly because it has 2 stages/functionalities. One is a de-esser with a lot of parameters and the second is a general level detection which ensures it is always operating at a good level. This means you don't have to set it as aggressively to catch and get reduction in more quiet sibilants.
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
Old 12-10-2018, 08:12 AM
Peter Duemmler Peter Duemmler is offline
Softube Weiss Deesser.
http://www.merlinsound.de
Old 12-10-2018, 11:25 AM
Thanks, folks. I've got a few to test out now. The only ones I've ever tried in the past turned out to be little more than glorified notch filters, so I just sort of stopped trying them out.
Old 12-10-2018, 03:02 PM
JFreak's Avatar
JFreak JFreak is offline
^^ this.
Janne
Old 12-10-2018, 03:21 PM
crizdee's Avatar
crizdee crizdee is offline
Brainworx Dynamic EQ. Lots of filter types to choose from, separate key filters, a max gain setting to limit how much it boosts or cuts. M/S mode so can treat the mono and stereo field separately. lots of good features.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-10-2018, 05:03 PM
leftalive leftalive is offline
Has anyone tried that new Waves Sibilance thing yet? I picked it up for freesies and kind of forgot to even try it out.
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
64GB DDR5 5200mhz RAM
2 Samsung 980 Pro 1TB SSDs
Samsung 850 Pro 1TB SSD
LG 34" Ultra-Widescreen monitor
Pro Tools 12.4
A loaf of bread
A stick of butter
A lot of rye whiskey
HTML code is On
A question about de-essers and signal flow etc puppethead Tips & Tricks 8 02-18-2007 09:03 PM
Questions about latency, signal flow and de-essers puppethead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-20-2007 02:52 AM
Notes going transparent? soulcatcher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-20-2006 09:57 AM
De Essers? Anduril 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-23-2005 09:35 AM
Transparent equipment?? Jack Wagoner General Discussion 16 09-03-2002 04:24 PM
