Old 09-10-2012, 06:57 PM
vudoo vudoo is offline
Default PT 10 CLip Gain to PT 8
I need to export my foley session edited on PT 10 with tons of clip gain for final mix. I'm still mixing on an HD6 with PT 8.03. Is there a way to export the PT 10 session and preserve all its clip gain for import in PT 8 ??? THx
Old 09-10-2012, 07:36 PM
Craig F Craig F is offline
Default Re: PT 10 CLip Gain to PT 8
render or convert to automation
Thank you,
Craig
Old 09-10-2012, 07:39 PM
Post Re: PT 10 CLip Gain to PT 8
Edit-->Automation-->Convert Clip Gain to Volume Automation. Any clip gain above +12dB will not be converted to volume automation.
Old 09-10-2012, 08:09 PM
thx guys!
Old 09-10-2012, 10:14 PM
cjguitar cjguitar is offline
Just to clarify, clip gain above +12db isn't dropped, it still converts to volume automation but it tops out at +12db obviously.
Chris M. Jacobson, CAS
Re-recording Mixer, Sound Designer
IMDB
HTML code is On
Adjusting Clip Gain On More Than One Clip Blank Frank macOS 17 05-15-2015 06:34 PM
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 12:46 PM
Export Clip With Clip Gain BobbyDazzler Pro Tools 10 0 03-03-2013 03:06 PM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
How to use X-Key on clip gain? Frank Kruse Post - Surround - Video 6 11-01-2011 11:14 AM
