Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 10-28-2011, 09:23 AM
maestrochase maestrochase is offline
Default Problems with New Fast Track C400
The Fast Track C400 came out and I immediately thought it would be perfect for my set up. Unfortunately after downloading/installing the latest drivers from Avid/M Audio's website and plugging the device in, the preamp/input pots are scratchy and at the top 5% of the gain range, the self-noise is amplified exponentially. It's a gradual rise of hiss up until the final 5% then there is an audible bump and a 12db (at least) increase in noise.
I am thinking that I just received a faulty unit, but I wanted to make sure that nothing is wrong on my end. My computer/OS is Mac OSX 10.7.1 Lion on a 2011 Mac Mini Server 2.0ghz i7 with 4gig of ram and 2 internal 500gig hard drives. I installed the latest drivers from Avid's website before plugging the device in and I followed installing instructions dilligently. The audible noise is evident without any input devices plugged in, and I can both hear the noise through headphones when only using the control software or when recording with Adobe Audition or Pro Tools SE.
Any ideas? Should I return/replace for another C400 or go for another device? Thanks for any advice!
Old 11-24-2011, 05:33 PM
northstar northstar is offline
Default Re: Problems with New Fast Track C400
What did you do? I'm waiting for mine to arrive and wondering if you replaced and still had the issue?
Old 01-17-2012, 03:49 PM
santolini santolini is offline
Hello, I have the same problem with the gain knobs. Is this normal? Waht did you do?
Thanks!!
Rui Santos
Fast Track c400 issues (help) stereopole FireWire & USB Audio Interfaces (Win) 8 01-11-2016 05:53 AM
Fast Track C400 Win8 Update laetidjey FireWire & USB Audio Interfaces (Win) 11 10-23-2013 11:44 AM
Fast Track C400 w/ PT11 ?? sandersonc84 Pro Tools 11 1 07-05-2013 03:44 PM
PT10.3 and Fast Track C400 frcjt macOS 2 09-16-2012 10:07 AM
Fast Track c400 Suddenly Clear Pro Tools M-Powered (Win) 3 10-29-2011 02:17 PM
