Gray Space at Beginning: Before 00:00:00
All of the sessions we have in PT 7.4.2 are opening, in the Edit Window, with a large empty gray area to the left of the actual tracks. The session start time is at zero, and all the track start at zero; this isn't usable space so there's no dragging over there. There's the track names,colors,inserts, etc section, followed by a large empty gray area, followed by the actual session.
Any thoughts? stu |
Open the Session Set Up window, and change the Session Start Time to 00:00:00:00, and select "Maintain Time Code", and you will have access to all that space!
Michael McDonough, M.P.S.E. Michael McDonough Sound Design |
AutoScrolling On?
Session startup is aleady at 0:00.
Autoscrolling is on. stu |
"Open the Session Set Up window, and change the Session Start Time to 00:00:00:00, and select "Maintain Time Code", and you will have access to all that space!"
Michael, We went to the Session Setup window and, as I said, it's already all set to 00:00:00:00. We don't see any spot that said "maintain time code" though. (We thought we'd try to reset things.) Nothing's "offset" or anything like that and everything works...just a big gray area before the tracks. stu |
Oh..ok...I see the scrolling thing...well, that's annoying. I hate "page" mode...so why does this happen when continuous mode is on? Seems like a waste of real estate to have it there just 'cause I want scrolling. Is this a bug or something that's adjustable? What would be the purpose of the empty space?
stu |
To place the current position in the middle of the Edit Window... which is what that scroll mode does.
Rail
How else would it be? If you have scrolling set to Continous, that means the cursor is always in the center of the screen. If you return to the beginning of your timeline, then half of the screen is nothingness. It's not a "waste or real estate." Nothing should exist before the beginning of your timeline. It would be like walking to the edge of the universe and expecting to see more stars through the curtain.
Pascal Garneau | IMDb |
I don't mean to be dense here...something still doesn't make sense to me. Thanks for advice, stu |
Space bar stops then goes back to beginning | TestPilot | Getting Started | 4 | 01-07-2014 01:01 PM |
Large gray bar | zoff | macOS | 3 | 03-07-2012 05:05 PM |
dead space at beginning of bounce | xl999 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 24 | 07-08-2010 03:58 AM |
in the gray | groovilator | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-18-2006 11:23 PM |
Gray Area | Sstudio | Pro Tools TDM Systems (Mac) | 1 | 07-28-2001 07:54 AM |
