Old 10-29-2015, 09:52 AM
Richard901 Richard901 is offline
Default Enter a carriage return in the Comments area?
I'm trying to enter carriage returns in the Comments Area in the Edit window.
Page 209 of the manual:
To enter a carriage return in the Comments area, press Shift+Enter (Windows) or Shift+Return (Mac) on the alphanumeric keyboard.
I can't get this to work.
Here's the comment as I'm typing it using Shift+Return for each new line:
Here's the finished comment:
I've searched the forum and found that people were having this problem as far back as PT7.1.
Pro Tools 2023.9
Ventura 13.6
Old 10-29-2015, 10:25 AM
john1192 john1192 is offline
Default Re: Enter a carriage return in the Comments area?
i can confirm this on my system as well .. BUT found something else .. if you open up the track by clicking on it's name .. you get the track name / comments box and it does look correct there ..
and you can get it to work by adding 9 spaces after you last character .. so 1) ONE now 9 spaces 2) TWO
it works but stupid ..
and if you add the 9 spaces it will not look correct in the track name / comments box ... again stupid
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 10-29-2015, 11:35 AM
Craig F Craig F is offline
it auto condenses the same way the track names shorten
the condensing algorithm should probably be updated
Thank you,
Craig
Old 10-29-2015, 12:39 PM
the condensing algorithm .. sounds painful ...
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 10-29-2015, 12:56 PM
Thanks very much for the quick replies.
Nice workaround!
Good idea!
Comment column - variable width would be useful - especially on large monitors.
Pro Tools 2023.9
Ventura 13.6
Old 01-03-2019, 11:27 PM
SplashChoke SplashChoke is offline
In PT 12.8 it seems to work with the '9 spaces workaround', but only if the first line is long enough. My comment "Kick<9 spaces><shift-return>beta 52a", still prints on a single line, while "Vox Peter<9 spaces><shift-return>KMS 105" prints correctly on two lines. Weird!
Carriage return in comments dialog Jon E. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-02-2007 06:41 AM
Return/Enter key won't return to 0:00 on Pro Tools LE on Mac marcnyc Pro Tools M-Powered (Mac) 2 08-31-2007 02:29 PM
Using "Return/ Enter" Key.... powerjoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-04-2005 12:32 PM
G4 interal CD carriage Laffman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-23-2002 05:28 AM
Enter / Return Key In PT5.1 Import Dialogue Box jimlongo Pro Tools TDM Systems (Mac) 17 03-02-2001 09:35 AM
