Old 12-23-2013, 08:41 PM
LSW LSW is offline
Default Importing audio files for remix - convert or set session to match source audio?
In PTMP 8, I usually use 24 bit 48 K as my default sessions settings. I have a few songs originally done in Logic 5 on the PC and they are 16 bit, 44.1.
PT will convert these files upon import to my default settings - or, would I be better off just creating a session to match the source files? Is there any benefit or harm with the conversion?
It's OK if there's no benefit, as long as it doesn't mess anything up. It's going to be mostly just a remix, but I may want to add new parts which I would rather do at the higher bit and sampling rates.
Thanks!
Old 12-24-2013, 04:17 AM
Default Re: Importing audio files for remix - convert or set session to match source audio?
Thanks!
Unless you're mixing audio for video there's no real reason to use 48KHz. Stick with 44.1 KHz. As far as your question - work at the imported files rate and depth. 48 KHz isn't going to give you any benefit over 44.1.
Jack
QAPLA!
Old 12-24-2013, 01:37 PM
LSW LSW is offline
Thank you MusicMan - that was my gut feeling, it's good to have it confirmed.
I've just been going through my projects I've completed over the last 10 years - not a lot of stuff, but it seems that I did more before I got ProTools, which was at V6 when I converted over. The decreased productivity was not the fault of the software, just life things. Logic 5 was really not a very good program. I think that it would only do 44.1/16 bit, or that was the limitation of whatever interface I was using at the time.
But thanks again and Happy Holidays!
Old 12-24-2013, 07:12 PM
Ben Jenssen's Avatar
Ideally you would create an empty 44.1 session at 24 bits and import the files/tracks. The files would go thru no conversion but any processing or new recordings would benefit from the extra bit depth.
Old 12-25-2013, 04:14 AM
Actually there would still be the upconversion to 24 bit from 16 bit.
Jack
QAPLA!
Old 12-25-2013, 06:45 AM
JFreak's Avatar
JFreak JFreak is offline
I only use 24bit/48kHz unless someone pays me extra for 24bit/96kHz.
I've never understood the compromise of 44.1kHz and its upsampled 88.2kHz versions; and had someone asked me, I would have chosen 64kHz as the one and only sampling rate ever available. But that would not have made it possible to enter the bigger-number-is-better game, would it?
Janne
Old 12-25-2013, 09:11 AM
The 44.1 KHz is as you know the CD Red Book standard so that's the only reason it really exists. But exactly why that specific number was chosen I have no idea. I know that the electronics in use at the time it was developed may have had something to do with it as well as upper limits of human hearing, but still..........
Jack
QAPLA!
Old 12-25-2013, 10:46 AM
JFreak's Avatar
I know, but it's an end product standard. What's the point in mixing in 44.1/24 because that is not the RB either..?
Janne
Old 12-25-2013, 12:40 PM
Craig F Craig F is offline
My understanding in part of why 44.1 was chosen was so all on some classical piece that the wife of an exec at Sony love(d) would fit on one disk.
Don't know how correct it is but it's a good story
Thank you,
Craig
Old 12-25-2013, 02:17 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
That story was put out as PR. The real reason 44x16 was chosen is because it was the highest sample rate and bit depth that could be encoded as a video signal in order to facilitate editing with VTRs rather than mainframe computers. The playing length was determined by the length of a Sony UMatic video tape cartridge. The disk is really a miniature Philips video disk that was designed to be pressed in existing vinyl plants.
The pioneers of digital audio found after extensive research that 50 kHz. and 21 bits is the minimum level of quality that can be considered transparent and the optimum would be around 60 kHz. Lower sample rates involve magical infinite filters that don't exist in real world designs.
My experience has been that the damage is already done in the original recording so up-sampling is just adding unnecessary degradation. If I'm starting a recording, I work at 48 or 96 depending on the complexity. If I'm importing audio, I just add 16 bit files to the session but I set the session to 24 bits for recording and 32 float for audio suite signal processing.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
usaved PT session saving unsaved audio files to audio files folder mermermer Pro Tools HDX & HD Native Systems (Mac) 1 07-18-2012 11:50 AM
Imported Audio Match Session Tempo noah330 macOS 2 01-14-2012 04:18 PM
Audible Audio does not match WAV files!?!? zsjordan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-13-2010 09:36 AM
Help! Reason audio files don’t match PT’s grid. Keyque99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 11-12-2002 09:28 AM
What's the best way for importing 16 bits audio files on 24b session Alex Rodriguez Pro Tools TDM Systems (Mac) 3 03-24-2002 03:47 PM
