#21
Re: Artist Control - Has anyone managed to solve the disconnection issues?
Just another piece of info if it helps;
If, while the Unit is powered up, I unplug the ethernet cable and insert it again, the Eucon icon greys out but the Artist Control doesn't freeze, I can just power off and on again. That gives me the impression that my theory about the ethernet port on the iMac being at fault may be barking up the wrong tree. Is there a possibility that there is a fault with my Artist Control? I've conducted the fault finding (powering up with both bank and right nudge held) and everything is fine. I'll be gutted if the unit is at fault because it'll have taken me nearly 2 years to find out! A little past the money back period!!! |
#22
OK, I think we are narrowing it down. When this happens is the unit still displayed as connected in EuControl ? What is displayed on the Mix's OLEDs ?
I'm starting to think its a hardware issue, you can try pulling the Ethernet cable and putting back and see if that auto connects (do not cycle power). Let me know.... |
#23
I posted the last post before I read yours ! Pulling the Ethernet cable and putting back the unit should reconnect after a few seconds. No power cycle necessary.
#24
Ok. Just unplugged. Icon greys out after 5 seconds. Plug back in , wait 5 seconds and it connects automatically.
Sent from my iPhone using Tapatalk |
#25
Unfortunately its looking more like the unit has an issue. I'll PM you.
#26
Bugger!
Really appreciate your help though. Sent from my iPhone using Tapatalk |
#27
Hi guys,
Just thought I should chime in about this. I use an Artist Control with my Cheesegrater Mac Pro and it behaves well. However, my wife has an 2015 3.3ghz 15,1 iMac and there is a major Ethernet issue with these machines. She cannot use ethernet because it drops offline very often.
The only way for her to work on the machine is via Wifi. It's in Applecare, so we may send it back. There have been various 'updates' from Apple where they have claimed to fix the issue, however, it has never fixed her ethernet dropout issue. Good luck with your unit! Best :) Walt https://www.google.com/search?q=appl...utf-8&oe=utf-8
It's only R'n'R but I like it. |
#28
That was an issue I looked into after stumbling across a thread describing problems with Ethernet ports on the iMac. My Artist Control just freezes (anywhere between 5 minutes and 9 hours) needing a reboot. I found that if I disconnected the Ethernet cable from the unit, it would automatically sync up again once plugged back in. So if I do have random Ethernet disconnections, that would not cause my unit to freeze. Together with Eddie Jones, we concluded that the unit itself was possibly at fault. Replacement unit is on the way and fingers crossed I never experience the freezing again.
#29
Update.
My Artist Control was sent back to Avid and they reproduced the freezing. Definitely a fault the the unit which really puts my mind at ease in a way. After upgrading my entire studio, rewiring the house, investing in the best networking equipment on the market in futile attempts to fix the issue, it was the pesky unit itself! If it wasn't for Eddie Jones taking the time to offer his advice, I would still be chasing my tail so a huge thanks to Eddie. Sent from my iPhone using Tapatalk |
#30
Unit repaired (although I wasn't informed what the problem was) and I've had it running for 20 hours straight with no problem. It's Fixed!!!!!!!!!!!!!
2 avid artist mixes and one artist control V2 for sale | Brandonx1 | Buy & Sell | 2 | 03-21-2016 09:55 PM |
Artist Control connection issues | GreenWire | Artist Series | 3 | 07-22-2015 11:54 PM |
Current issues with Artist Control and Mix | esplace | Artist Series | 1 | 06-23-2013 02:09 AM |
Artist Control-So Many Issues | RBowlin | Artist Series | 26 | 06-15-2013 07:17 AM |
Touching Artist Transport Freezes Up Artist Control in Logic | sonofmack | Artist Series | 1 | 03-13-2013 08:22 PM |
