bad volume or filename -37 when importing session
It seems every time I try to import session data, I get an error if I've used some of the same files in both the source and target sessions. I believe pro tools used to add a .1 to files to the added files that had the same name. now I get this error. Also, If I tell it to referance the audio files in the source session it works, until I try to do a "save session copy" thus attempting to put all the audio files together in one audio files folder. Any thoughts on this would be might appreciated.
Re: bad volume or filename -37 when importing session
yes this is the infamous "-37" error. multiple files, identical names in different folders and PT tries to throw them all into one single folder when importing or saving in.
I think what might work is to import the track with "link to media" then open the project browser. activate "select parent files in project browser" in the region list. then open the audiofiles folder in the project browser. select all the region on the tracks you imported and PT will select the according files in the project browser. now select "copy and relink selected" in the project browser´s toolbox. PT will ask where to put the files. when you chose the target session´s folder (the one of the session you are in now) PT will most likely rename those files if the same names are already present. If you get -37 again you have no other choice than to repeat the procedure and chose a new folder to copy those files to. Unfortunately this is due to the incredible asset-management capabilities of PT. It leaves most of the work to the user unfortunately... frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Importing many session files to make a new long session | velwestvoices | Pro Tools 10 | 4 | 04-30-2012 03:38 PM |
Importing a mix session template into a record edit session | bryced87 | macOS | 1 | 04-27-2012 04:24 AM |
importing session data, session now lags | kyle_182 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-10-2010 12:16 PM |
Importing tracks and volume automation! | uno1234 | Pro Tools TDM Systems (Mac) | 24 | 01-14-2008 12:26 PM |
importing audio/trax from a pt7 session into a pt6 session | bullyboy | Pro Tools TDM Systems (Mac) | 1 | 08-15-2007 05:36 PM |
